quick ? - Newbies Forum
quick ?
Tuesday, May 17, 2011 12:13 AM
would a gauge cluster from 00 cav fit into my 99.
Re: quick ?
Tuesday, May 17, 2011 12:19 AM
no.
Re: quick ?
Tuesday, May 17, 2011 12:20 AM
thanks
Re: quick ?
Tuesday, May 17, 2011 4:55 AM
Not only would it not physically fit... (but you could MAKE it fit by doing some cutting.. or swapping in a 2000+ dash assembly...)
But the electronic controller (called the Body Control Module, or BCM for short) you need to run the 2000+ cluster isn't part of a pre-2000 car.
So even if you made it fit in the car, it would never work unless you swapped over all the electronics as well. I've done it, it's an awful job.
Re: quick ?
Tuesday, May 24, 2011 12:40 AM
would it matter if its from a 99 auto cav.
Re: quick ?
Tuesday, May 24, 2011 4:47 PM
its still a no
Re: quick ?
Tuesday, May 24, 2011 10:24 PM
how come
Re: quick ?
Tuesday, May 24, 2011 10:39 PM
John Lenko wrote:Not only would it not physically fit... (but you could MAKE it fit by doing some cutting.. or swapping in a 2000+ dash assembly...)
did you not read that?
Re: quick ?
Tuesday, May 24, 2011 10:42 PM
wat does that have to do with an auto cluster from 99 goin into my 99 mt
Re: quick ?
Tuesday, May 24, 2011 10:44 PM
95-99 cluster auto or stick store the mileage within the cluster 2000-2005 hold there mileage in the bcm. there more too it then just that also.
Re: quick ?
Tuesday, May 24, 2011 10:46 PM
ah you werent clear. are you trying to gain a tach? it will work but your mileage will still be wrong.
Re: quick ?
Tuesday, May 24, 2011 10:48 PM
i just want the tach.
Re: quick ?
Tuesday, May 24, 2011 10:52 PM
it will work then. but like i said the mileage wont be the same.
