Hey there,
Just a quick question ...how many of you have custom downpipes and did you make them yourself or have someone make it for you? If you made it yourself how'd you do it? Thanks
I do, the process was get pipe, get flange, make bends weld together... Tada...
So do i. Same process as above, but the shop that build my header did it.
its an old concept. time for something new to take the reigns. - Z yaaaa
custom 3in
heres the down pipe, down pipe has 2 feet of pipe welded to it then the magnaflow bolted on the end
I had mine made by a friend. Its for the pacesetter header.
i do, kinda. i put a pacesetter header on and used the provided downpipe flange (3in long). i took my factory downpipe (which has been tested by many as good to 250) and cut it down to the top of the cat, welded my flange (pacesetter provided) to the top of the cat. then i took an inch off at the bottom of the cat. then i hooked it up to a magnaflow cat-back system. i'm very pleased with the results. : D
Some good looking downpipes in here. I did all the cutting and fitting myself, then I taped the pipes together and marked them with a line and marked it A to A, B to B etc. Then just took them to a shop and had them weld them for me. I didnt do a bunch of welds together just so I could make sure the next peice was going to fit. Seemed to work out great.
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
An other style of turbo downpipre (mine)
Boost Lover
