I was wondering if i could swap the exhaust maifolds from a 97 to a 98 cavalier? i have called Canadian Tire and they said that the manifold gaskets are different so im not sure if they'll be interchangeable. what i am trying to do is take the flexpipe out completely and use the older style spring kit.
thank you in advance,
nathan
Head is different so I want to say no.
nope won't work at all... the entire top half of the motor is different
SIGH ............................
WHAT MOTOR ?? IT KINDA HELPS
2.4 97-98 would be the same , ohv slightly different , but YES they would swap over as far as the bolt pattern , the exhaust ports were moved over a little from the 2.2 to the 2200 design , and you could port the stock manifold to match the movement in ports
or just buy a header for it
^^^ what he said... i have asked the same question
jf the gasket is different then we know its a 2.2
thanks for the input.
and it is 2200.
GME Chat User: Speedline02 wrote:jf the gasket is different then we know its a 2.2
the 2.4 gaskets are different also , 96-98 have the egr slot and the 99-02 doesnt have the egr slot
[quote=97cavie24ls(™)]
the 2.4 gaskets are different also , 96-98 have the egr slot and the 99-02 doesnt have the egr slotyour right
but he said 97 to 98
so im guessing it wont work? lol
TheSundownFire (JBO Chat) wrote:Head is different so I want to say no.
GME Chat User: Speedline02 wrote:nope won't work at all... the entire top half of the motor is different
[quote=97cavie24ls(™)] ohv slightly different , but YES they would swap over as far as the bolt pattern , the exhaust ports were moved over a little from the 2.2 to the 2200 design , and you could port the stock manifold to match the movement in ports
without machine shop work, the answer is no.
