A friend gave me mint 18" wheel 4 bolt pattern with Azenis 225/40R 18 92W tires off his Mini Cooper S. Any way I can cahge the hups on my 94 cavalier so that they will fit??????????? Any advice would be appreciated........thanks
There is no way that would be cheaper than buying a new set of wheel. Sell the wheels and use the money to buy a set that are actually made for your car. That's the cheapest way.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
Yes, sell wheels. Keep tires.
you could try adapter spacers with acorn nuts, but they might cause an off balance at the rotor. and you have to find some one who makes them in 5x100 and have studs in a 4 bolt pattern. which isnt gonna happen most likely. ive seen 5x100-5x110/115 and 5 bolt to 6 bolts for trail trucks, but thats it.
like said above....ditch the rims, keep the tires and find rims to fit the tires in your current vehicle.
actually guys I believe the 4 lug hub assy. off a Saturn Ion will bolt up to our spindles...not sure what the bolt pattern size is on those though...
Scott Richner wrote:actually guys I believe the 4 lug hub assy. off a Saturn Ion will bolt up to our spindles...not sure what the bolt pattern size is on those though...
even if that is true, is it really worth it to swap all the hubs for a set of wheels?
87 Firebird
All stock...........lol.
