Swap question what is better/easier - Newbies Forum
Sunday, June 21, 2009 1:10 PM
So the 2.2l 2200 in the 2000 has got a rod thats knocking and i want to swap the engine which is the easiest without using the 2200 engine
the car is 2.2l 2200 5 speed 2000
to stay with a stock interior what electronics work with the gauges?
i want more power so i was thinking of the 2.4 what transmission do i need and are the axles the same?
i have very little ability for anything that involves programing a computer so what can be done to avoid passlock (if applicable)
Re: Swap question what is better/easier
Sunday, June 21, 2009 9:40 PM
If you go with the 2.4 you will need the 2.4 transmission. Same goes for the Ecotec.
Im sure either/or will take the same ammount of work. Your axles will work. Mounts can work.
And I believe with the engine harness to either motor can be plugged in. Will need the computer too or reflashed.
Wednesday, June 24, 2009 9:12 PM
just get a 3400, keep your tranny, get harness, ecu, and other things(search is your best friend), and call it a day, or do what craig said
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride." -Amen
Thursday, July 02, 2009 10:49 PM
3400
