I purchased my sunfire in Oct '05 w/ 79K on the clock.
currently sits right below 96K
its suddenly started burning/dripping oil. is there any one place i should look @ replacing something?
also....
driver side window motor seems to be going out...
&& power top keeps blowing fuse.
I'm used to having my hand in my 2 Diesel Mercedes, so you point me in the right direction && i'll be great
Thanks in Advance.
Matt
Can't help you (specifically) with the oil leak. (Sorry).
Changing the driver side window motor isn't fun, but it can be done. The regulators and motors are all riveted together and into the doors. Motors are available on eBay or online vendors. Aftermarket regulators for the convertibles aren't available and OEM ones are near-$300 new. Sometimes you can find a used regulator in a wrecking yard, but convertibles are not plentiful. Best bet is a new motor on your old regulator, but be careful of the clock spring. The third gen convertibles use two electric motors to run the top. If you're blowing fuses and the wiring seems okay, the motors may be going bad. If you ever see a pair of motors on eBay, you should pick them up. (Always replace them in pairs.) Navigate over to the third gen forum and look at the convertible service manual sticky at the top. Good luck. - Mark
