Can anyone help me? I got a shifter knob and was trying to get my old one off. I have a 1998 Pontiac Sunfire. but i cant unscrew it and theres no bolt to unscrew. But theres a little like slit on the front. Any Help here.
There's a U clip in that slit. Take a small flathead screwdriver and pry it out.
i looked for it and couldn't find the u clip
the U clip can get pushed in sometimes. try to find it with the flathead. if theres nothing there then just pull up on the shift knob
I cut mine off when I did my short shifter. lol.
![](http://img360.imageshack.us/img360/1427/siggymv9.jpg)
JBOK.org / J-Bodies of Kentucky
chainsaw. thats the tool GM recomends. i swear, look it up, its in the owners manual lol.... no really, it should just come right off. pull HARD cause its prolly glued on
Mike wrote:The auto to manual swap is not as involved as you would think.
Get all the parts you need in a pile, and drive the car into it.
They will find their way into the correct places.
there's guaranteed to be a clip in the slot in the front. look harder
i used a pair of really skinny needle nosed pliers when i took mine off.. try that.. or even a pair of tweezers if you throw them out afterwards bc they can fit in a lot of places that a flathead screwdriver cant. bend the tweezers all the way open where its opened up and get a good grip on one end and stick it there as far as you can then lean it back, that should catch the u-clip.. the tweezers should be able to at least pull it out enough you can grab it with the pliers or a flathead..
