This question isn't for me and I can't see the car personally, otherwise I'd be able to help a bit...
The crank pulley that is going on is about 3/4" smaller diameter than stock. Question is, will the stock tensioner be able to handle the slack caused by the smaller crank pulley, or should a shorter belt be purchased?
The engine is currently out of the car and the AC compressor is still hooked up to the lines holding the refrigerant in so that option's out
Strange you ask Kardain, I have the exact same issue.
Heres my calculations, and im not sure if i did them right
assuming the pulley is a little more than 3/4 of an inch bigger (for calculation purposes) and rather it is .8 of an inch bigger.
the circumference of a circle is RXRXPi which equals
0.4 X 0.4 X 3.14
which comes out to
0.5024,
which translates roughly into a half inch. So...if the Idler can take up a good half inch, then it SHOULD be ok, and the way i figure, it doesn't even have to take up that much, since the belt doesn't go completely around the pulley, rather goes about 2/3, which translates to this
.5024 X .66 = .331584. which equals
1/3rd of an inch.
so, unless im smoking crack, it should be able to handle it. Hopefully i calculated right,. Anyone else have any input?
![](http://www.nwuonline.com/images/sig2.jpg)
nwuonline.com
Proud member on JBNW.org
JBO member since 2004
Jebadiah04 wrote:Strange you ask Kardain, I have the exact same issue.
0.4 X 0.4 X 3.14
which comes out to
0.5024,
1/3rd of an inch.
circumference is 2*pi*r, or pi*d
http://en.wikipedia.org/wiki/Circumference
meaning the .75 diameter difference will have a circum difference of 2.3561925" (2.25 or 2.5" depending on how belts are manufactured)
pi*r^2 (what you did) is area
oh, i knew it was somethin like that
might think about shortening it up bout 2 inches. ill have to go over and get my exact measurements and do the math.
nwuonline.com
You'll need a smaller belt. The stock tensioner will not take up that much slack.
^^ Just the person that I was hoping would answer the question
Also, just what I thought the answer would be.
unfortunately, thats what i thought it would be too
anyone have any idea of exactly how much smaller? or should i just grab my old one, head to napa, and get one thats about an inch shorter on the loop?
nwuonline.com
Kardin, if it is an E-bay crank pulley. Please ensure it is not out of round.
Joshua Dearman wrote:No, this IS the crap pulley from ebay...this IS NOT one from Mr. LD9.....man I wish it was.
This is actaully a crappy one from ebay that I had to do hours of machine work to get the way it should be......seriously they are crap and waaaaayyy out of round.
