is there any way to have both high and low beams running at the same time on a 95 cav?
any help would be appreciated
click to turn your highs on but hold in the handle and both will stay on. if you let go, then it clicks over to high beams.
what i mean is that i dont want to hold the handle in, i would like for both to be on while i drive. i.e. a switch or something to that effect that i could turn both on.
just a dumb question but why??
because i have hids and yellow high beams. i want to drive with both on. the only reason i ask is because i have similar setups on a few of my honda's.
HIDs should be way bright enough....having both on will overheat your harness
^^Not to mention blinding other drivers (potential law suit).
_________________________
yes i know not to drive with the high beams on when there is on coming traffic. so by the looks of it nobody can help me out with wiring a switch to light up both sets at the same time. any help.
since its a switched ground setup, its doable, but not easy.
