first off I've got an 04 sunfire 5speed
need a clutch, iread alot of the stuff on here.. and other places but still confused on the best setup i should go..
i am N/a right now, but plan to go stage 2 maybe 4 later on..
from what i read i should go either stage 2 or 2+ for the clutch, am i wrong?
what are good brands, compared to others. and best locations to snag one cheap
second question
i installed a air fuel gauge, and it said to hook to one of the wires on the 4 wire o2 senor...
ok i did, if you know the sensor it has 2 white, a black,and a greay..
right now i have it hooked up to one of the white ones, and my gauge is saying it is allways lean..
does that mean i need to put it on the other white one? or did i do something wrong..
the instuctions say to put on the "high" wire verses the "low" wire that comes from the controll modual( or w/e it is)
it says one is 12v and one is ground... i drew the conclution that the black as ground and grey was power. and the 2 white is what i was looking for.
before i go crawling down under agian, i would like a heads up if anyone got any..
thanks
so what your saying is i was right.. if i want to go stage 2 maybe 4 later down the road.. a clutch that is stage 2+ will be good?
the bump was more in reference to my second question..obviously you didn't read it.
no, i did. but i dont know the answer. what type/brand of gauge? did you get a wideband o2 sensor? have you done any research?
i got glowshift gauge... no im not running wideband.
was told it will still give me enough accuacy to make sure its burning around where it is supposed to.
i will in the future but for now im working on the motor
... i did some research and really coudnt find anything
basically this..
the o2 has 4 wires... grey black and 2 white
i came to the conlusion the black is ground grey is power, and the 2 white is the high and low signal to the computer thinger...(not the computer but the box it runs to)
i had it hooked to the one... and was allways getting lean readings... but when i floored it it would jump to the top of rich.. pegging the needle.
if i put in on the other white wire... then i only get a pegged needle at rich..... no change in any driving conditions..
maybe the gauge is bad? or even the o2????
any links that i missed would be appreciated.. im allways willing to read.. just didnt find what i was looking for.
noted... point me in direction of a good wideband?
will that wideband be able to replace one of my o2? or i have to get another bung put in..
wow, sounds like this noob really needs a good bitch slap! Dude, seriously, go thru the forums and just read... whatever you think you want to do has most likely already been done.
its truly funny how you can tell that this site is invested by a bunch of snoty f u c king think they know everything kids.
i'm on a forum for camaros, and i can tell you this, not ONCE in 5 years on that site have i seen any treatment of other like this, if there was. INSTANT BAN
have some respect you F U C K I N G A S S H O L E!!!!
you know maybe some people have lives and want to do this on ther FREE time, which ovoiusly most of you have all day from the way you post all over this site.
F U C K THIS this site blows for info anyway, you people need to get a life
Wow! Ur on a site for camaros!?!?! I'm sorry, let me bow down! So am I. I'm also on LS1tech and Hybridz as well. Not to mention numerous solstice forums also. Who the hell cares! You come on here talking about stage this and stage that! What the hell does that even mean???? I haven't seen that talked about on LS1tech! Or are you one of those lucky bastards with a v6 auto? "But but but its got t-tops!" Whatever!
Rich was honestly trying to help you, asking hp desires instead of stages... He is a respected member of the website and has been here for quite some time, as have I. We don't even know what you want to do! turbo? Supercharger? Nitrous? N/A? WTF?
Why the hell do you need a clutch in an 04 anyway??? Sounds like to me you haven't even learned how to drive stick yet! Let alone start modding a car with a stick! If you do have a camaro, why are you bothering? Unless it truly is a v6 that my cav will smoke!
So before you come on here talkin crap and thinking you are better than everyone else cause you are "on camaro forums" think about what you are saying and how you are phrasing it!
BTW, narrowband O2 gauges are pretty much useless! They tell you when you have your foot on the floor! Congrats, you should know that without having to look at a gauge!
uh.. not a v6 only pussies drive them.. its a 78 z28 with 355 pushing about 625... without nitrious...(150 shot)
Gravanatuning sells a wideband 0 sensor and gauge. and get the sand out of your vagina new guy. just do a little research before asking a question
mmmmmm...... daddy's car.....
go ahead and think its my dads car... but its not..
he has his corvette, so blow me.
its called saving your money and putting towards something that will be worth money some day.
