I saw a 95 z24 at the junk yard today and I was wondering if the intake would fit on the 2200. is it possible?
stock '00 2200 cavy
ummm z24's have the 2.4l engine, and the throttle body is on the front of the engine, as on the 2200 it is at the rear. It is just flexible hose so prolly, but i don't see why you would want too. no perfomance will come of this.
its not exactly flexible hose. its a formed rubber hose. it doesn't bend a whole lot.
GO PATS!!!
Juan Chavez wrote:I saw a 95 z24 at the junk yard today and I was wondering if the intake would fit on the 2200. is it possible?
I highly doubt it would work.
Like said before, the plastic pieces don't flex much...they are very solid so it wouldn't fit around the throttle body. Also, they work off an air box...it wouldn't be long enough and route the same to reach the area for the hole and the box more than likely wouldn't mount up properly.
Now this is assuming that you saw one with an stock intake and not aftermarket.
If it was aftermarket, I highly doubt the tube would route the same and fit correctly.
Sorry guys I think I caused some confusion here!!! I was talking about the intake manifold not a CAI. sorry for not specifying.
stock '00 2200 cavy
Juan Chavez wrote:Sorry guys I think I caused some confusion here!!! I was talking about the intake manifold not a CAI. sorry for not specifying.
Even still...a big negative on that one. Same theory comes into play, totally different motors, different heads and manifold bolt up.
