hey does anyone know where i can order some lowering springs im looking to lower my car right over this winter.. So I would apritiate any info thanx
Paul
www.gravanatuning.com
www.aplusperformance.com
theres a couple of places id go
or the classic...... www.ebay.com just watch out in there, if you see springs for like, 50 bucks, its probably a scam
oh, and get struts too. stock struts are not good for lowering
if your dropping 1.5 inches or less, get KYB AGX struts, if your going more than that, get Koni yellows. theres other struts taht are good too, like the tokiko D specs, but i dont know the lowering warranty on them
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
You can also look in the Classifieds on here to buy used and same yourself some money.
Rob
Sold 2/2/05
Or try reading the FAQ at the top of the suspension and brake forum. Best thing i ever did and it saved me a lot of money i was going to buy on something from ebay.
i hope you get struts too. really read the faqs in the suspension forum so you know what struts to use with which springs
Springs and struts and you may want to get a new camber kit. While you have all this torn apart, replace worn out suspension parts and bushings.
true good idea to give a check on things like tie rods, bushing and cv joints while everything is off. a camber kit isnt needed though for our cars unless you ride around at extremely low heights which unless bagged, no struts are really going to hold up to. once you lower it and get it aligned you'll be fine
One more thing... Assuming that you are doing the work yourself. For every bolt you take out, make sure to put it back in with a glop of antiseeze on it. Oh and you'll love air tools for this job, trust me!
Also, check the rating on the struts/shocks before you purchase them. Depending on the set you get, they can handle a certain amount of drop.
The Master wrote:Springs and struts and you may want to get a new camber kit. While you have all this torn apart, replace worn out suspension parts and bushings.
no need fora camber kit. im on eibach sportlines for almost 2 years now and everything is fine
