What does taking the tunr tube of a 2200 do? Does it add any power?
makes it sound a lil meaner, thats bout it
you actually noticed a difference in sound?
its a waste of 15 minutes. period. i noticed no sound change in my 2.4 and defintaely no power change.
GO PATS!!!
ok i dont think its in the 2200's and i heard a sound change.....
FOR SALE: (5) '95-'99 Z24 Rims
It's only for the 2.4s
If you go to the Team Forward Motion Library you will see that the 2200's do have a tuner tube. The 2.2's do not.
There is no performance increase to speak of. Just a sound increase. If you do other intake mods in conjunction with this, there is a difference.
98 Z24
RIP Specks
J m H m 1 7 wrote:its only in the 2.4's foo and it adds liek 45hp at the rear wheels from what i heard... fo showw niiiiigaa YEAH GGGGG UNIT NAAAAAAAAAAAAAWWWWWWWWWWZZZZZZZZZZZZZ
Umm that wasn't necessary
Well Jason, I guess what I took out of my daughters 98 2200 wasn't a tuner tube.
NJHK, thanks. That was deffently not called for from him.
The 2200 do have a tuner tube.
98 Z24
RIP Specks
Thanks Jbody2nr. I just didn't have the time to post those pics. At least someone took the time to go to the link and see the instructions.
98 Z24
RIP Specks
yeah the the 2200 come with them aswell as the 2.4s but the older 2.2s do not
Them tooner toobes must do sumtin, right bro??? Otherwise da factory wouldn't waste der $$ to put dem in. But what do dey doo??
I do not know !?!?! Anybuddy no what dey do?
Old Wolf wrote:Them tooner toobes must do sumtin, right bro??? Otherwise da factory wouldn't waste der $$ to put dem in. But what do dey doo??
cut down sound, thats why when you take them out....it gets louder.....
Brian Anderson {1999-Z24-4spd} wrote:Old Wolf wrote:Them tooner toobes must do sumtin, right bro??? Otherwise da factory wouldn't waste der $$ to put dem in. But what do dey doo??
exactly! same thing as the bong. some J engines are can be noisy as hell.
and my 99 Cavi with the 2200 had the tuner tube in it.
SO EVERYTHING!
take it out get a sub box and make a port. YAY =}
<img src="http://registry.gmenthusiast.com/images/mike1105/mycar.jpg" width="500" height="200">
[quote=BoltZ22exactly! same thing as the bong. some J engines are can be noisy as hell.
since we are in the noob forum....whats this bong you are talking about? does it have to do with the intake. does my 2.4 have it. does it help anything to take it out? how do i take it out. ah done with the questions now
2.2 deff has them, i remember that crap when i tore the stock intake out.
Scotty B wrote:2.2 deff has them, i remember that crap when i tore the stock intake out.
Not all 2.2's have them.
Mine didnt. Like I said I would put money down that only the 98-00 2200's have them.
Madjack wrote:Like I said before, building an engine like ours (2.2 or 2200) is a painstaking chore , since there is so few custom made parts. It's frustrating to me too, but that's what I like about doing this engine, it's the challenge.
Brian to answer your questions:
1. The bong, also known as the Intake Resonator, is in the inner fender driver's side. It just helps with noise reduction of air going into the intake system.
2. Yes. Your 99 Z has it on.
3. Some people say it does nothing but increase noise. If you look at the 'bong' it is an S shape plastic tube. Taking this out helps make the air going into the intake system smoother and less restrictive.
4. For removal go to this site for simple step by step instructions
Removing the Bong
Most everyone takes them off because they are restrictive.
98 Z24
RIP Specks
would taking out the bong do anything if u have a WAI or CAI installed?
1998 Sunfire, 2.2L auto
i left the bong in after installing my WAI on my 2002 2200....it sits outta the way, and it takes time to take it out...i just let it sit there as it does nothing.
Ryan Shissler wrote:would taking out the bong do anything if u have a WAI or CAI installed?
I believe in order to install a "CAI" style intake, you need to remove all the resonators and bong.
well then just a WAI. so it wouldn't do anything to take it out or leave it in. I'll take it out someday when i get bored
