i have a stock 2.3L sunfire, ive been searching for parts and its been hard to find them, ive noticed that some parts are interchangeable with the 2.4L... does anyone know if parts like a short ram intake or headers would also be interchangeable?
Intake, yes. Intake Manifold, yes should be. Header, not sure but I don't see why not.
I'm sure the 2.3 wizard will be here soon... (you know who you are
I'm sure the 2.3 wizard will be here soon... (you know who you are )
Yes we all know who you are..........
***Pssst NJHK........
[whisper]
who is it??????
[/whisper]
Madjack wrote:Like I said before, building an engine like ours (2.2 or 2200) is a painstaking chore , since there is so few custom made parts. It's frustrating to me too, but that's what I like about doing this engine, it's the challenge.
^^^^^^^^ You're just out of control Mister!
You can PM me if you want.....
Get AOL messenger or Yahoo so we can talk!
Intake manifold - Take the 2.3 Ho manifold. The 2.4 manifold doesn't fit unless modify.
Exhaust manifold - Use the 2.3 Ho exhaust manifold. The 2.4 headers don't fit and it's not even close unless you change the flange. TheRaceShop got 2 header for the 2.3 but they do not fit the J body.
Intake - Check Tranzgenic. They had an intake for the 2.3.
Tranzgenic Website
If you have a manual, you can get a chip from theraceshop.
You can get Ho or W41cams if you have a manual.
If you have an auto, you're stuck with the 95 intake cam or the 2.4 cams from JBP. You can get whatever exhaust cam you want.
You got those parts that you can get too:
Performance parts.
Cams:
Engle Cams www.englecams.com
CompCams camhelp@compcams.com
Crane E-mail them ONLY customerservice@cranecams.com
Adjustable Cam Sprockets:
GMRocketparts +/- 4 dregree PN# 22551543 www.gmpartsdirect.com
Heads:
TRS JoshGooding@The-Race-Shop.com
GSR scott@quad4forums.com
Crank, Block, Rods:
Eagle 2.4 H-Beam PN# CRS5710C3D
Eagle 2.3 H-beam PN# CRS5806C3D www.cnc-motorsports.com
GM Rocketparts Titanium rods PN# 22551571 www.gmpartsdirect.com
GM Rocketparts heavy duty forged steel crank PN# 22551525 www.gmpartsdirect.com
Headers:
no one makes them.
You would have to have one custom made. Or the Stock 89-92 HO
Piece flows best. however, some of us are working on changing the manifold flange on 2.4 headers to make it work on the 2.3.
Chips, ECM/ECU (95) :
Superchips www.superchips.com
GM (HO-W41) www.gmpartsdirect.com
Jet www.jetchips.com
S-AFC www.apexi.com
Flywheels
Fidanza www.aluminumflywheels.com
Valve Springs:
Crane Part # CRN-99846-16 www.summitracing.com
Lifters:
Melling 2.3L JB-2236
Melling 95 2.3L 96+ 2.4L JB-6051 www.melling.com
Valves/Valve Guides:
www.sivalves.com
Pistons
Ross www.rosspistons.com
Wiseco www.wiseco.com
JE Piston www.jepistons.com
Copper headgaskets:
SCE stock thickness Pn# 91704
avail in .032,.043,.050,.062,.080, and .093 thicknesses. (.043 stock) www.scegaskets.com
Clevitte Rod Bearings PN# - CB1388P
Clevitte Main Bearings PN# - MS1703P
ARP Head Stud Kit PN# - 281-4301
ARP Main Stud Kit PN# - 281-5401
There's a few other things you can do. If you got more question, you know who to ask.
Gilles
2.3 Ho
gilles i always wonder...do you write this stuff out or do you have it ready to cut and paste for these situations ?
"Freedom 'ought to have its limits"-George W. Bush may 31 1999 (who voted for this idiot?)
I have the list in a TXT file ready to paste
Only the list tough. I'll try to update the list since I don't think that gmpartsdirect sell the Kellog crank anymore.
Gilles
2.3 Ho
