What does this mean???
You have received a forum warning:
Warning: Please update your registry with proper info before posting again.
Expires: Friday, September 30, 2005 6:49 AM PT
if i were you, i'd contact a moderator using the Contact Us button for info.
is your email address correct?
pirates kick ninja asses, f00
Theres a "Rules" link on almost every forum page. It will take you here:
http://www.j-body.org/forums/rules.php
It's some good readin'... but I just noticed that it doesn't actually have anything written on the need for proper info in your registry.
Note that at the very bottom of every page here, there is a Terms of Service link.
http://www.gmenthusiast.com/terms/
There it says the following:
TOS wrote:In consideration of your use of the Service, you agree to: (a) provide true, accurate, current and complete information about yourself as prompted by the Service's registration form (such information being the "Registration Data") and (b) maintain and promptly update the Registration Data to keep it true, accurate, current and complete. If you provide any information that is untrue, inaccurate, not current or incomplete, or GME has reasonable grounds to suspect that such information is untrue, inaccurate, not current or incomplete, GME has the right to suspend or terminate your account and refuse any and all current or future use of the Service (or any portion thereof). GME is concerned about the safety and privacy of all its members, particularly minors. Please remember that the Service is designed to appeal to a broad audience.
Basically, the forums here aren't meant to be an anonymous sounding box so there is a requirement that you use your proper name when signing up. You can use whatever name you'd like in the forums, but your account should be registered with your real name.
Normally we wouldn't go through all this here but I felt it's of benefit to other people to see this since that TOS link isn't terribly obvious and there's probably plenty of members who haven't read through it.
As for warnings in general... they're just a convenient way for a moderator to get a message to you without making some sort of public spectacle or relying on you actually checking the email address you signed up with. Don't consider it any sort of punishment or anything and in the future, as mentioned above, if you have any questions about one just use the contact link and someone will get back to you eventually.
