does the cavalier use the same 2.2L GM engine as the S-10
I believe they did up until the Eco came out (2002). S-10s don't have Ecotecs. The engine you are talking about is the 115hp terror lol.
Rob
Sold 2/2/05
Ha, thanks for the info that is what I thought.
I believe the answer is yes...I believe it's the same 2.2 ohv Vortech motor.
Answer would oubviouly be no. RWD engines are not the same as FWD engines. try fitting your FWD tranny on a longitudinal engine. good luck
Carl ------ wrote:Answer would oubviouly be no. RWD engines are not the same as FWD engines. try fitting your FWD tranny on a longitudinal engine. good luck
You sure the small S10s are RWD? For some reason I thought they were FWD...I don't know much about trucks.
Carl ------ wrote:http://www.internetautoguide.com/car-specifications/09-int/1999/chevrolet/s10/
Yeah trucks are RWD (usually - maybe some imports are FWD but I'd doubt it), think about 4WD pick-ups, it's easier to add just a transfer case and front axle than changing the whole frame, tranny and rear-end
Thanks for the information
yes RWD and a different block casting.
and most parts are not interchangeable.
-Borsty
Only the trans and engine mount positions on the frame are diffrent. You can use a RWD engine in a FWD car ONLY if the trans mounts are the same.
Team Tach Out
Http://www.team-tachout.com/
Falmouth,VA
my buddy's s-10 has the same motor my 01 cavi had. 2.2 ohv find a pos s-10 and look, it'll be the same. i was shocked when i saw it
yay runnin mid 18s by summer
that says 2200 sfi < same motor in 2200 cavi
s-series.org
actually it say 2200 efi but the its still in the s10
