Almost everyone i know has or have had a bad water pump on thiers, what do you guys say?
this topic is beat, battered, and brusied!
some say they are. but water pumps go bad in every engine eventuly
go luck replacing it. its a pita on the 2.4's
yep what these 3 said is correct^
If you don't wan't to run into water pump problems, get a 1998 and under Porche 911 or a classic VW Beatle.
>>>For Sale? Clicky!<<<
Know whatcha mean. Mine died after just 8 1/2 years.
I have seen more GM water pumps fail largely due to DEXCOOL. Mine when 4 mos ago on my 99 2.2L.
Team Tach Out
Http://www.team-tachout.com/
Falmouth,VA
It's not so much that the Water Pumps are bad, admittedly they aren't the best design, but the bigger problem is where it is located and that it involves removing the head on a LD9 to replace which makes it seem like a much bigger problem then it is because you have a $800 repair bill.
Yella02-I promise I will return to you in one piece and this will stay up until I am safely home
Yeah not fun to do the water pumps on the 2.4's. It's almost easier to pull the engine out do it then put it back in. At least then you have some kinda room to work with.
Absolute Finest President
Hit us up at www.AbsoluteFinest.org
also checkout www.cnfxperformance.com
my father in law replaced mine with pretty much no problem. And the head doesn't have to be removed.
You must not have 2.4L engine if you didn't have to remove the head.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
The two 2.4's here haven't needed to have them replaced. A '99 with about 85,000 & a '01 with about 90,000. I read on here all the time that they're suposed to be crap and always go bad, but that just hasn't been the case here.
I believe the premature water pump problems with the 2.4L's were solved in either 99 or 00.
Can anyone confirm that?
You can do preventive maintenance and change the fluids every 1 or 2 years on water-cooled cars. So you remove any water-pump destroying deposits and use distilled water as it does not have calcium in it.
Hey, it is under $10 you'd spend every 1-2 years vs. $XXX + headaches in repairing the water pump. Do the math.
i have 96000 miles on my 2.4
no problems here yet
Yea, the problem is not that they are hard to replace, but you basically have to remove the whole engine to get to it. And if you have a shop do it its not cheap. Might as well have them check the head and some other @!#$ while they have everything out. Will be cheaper in the long run.
Wide Body Progress
I had mine replaced over a year ago. The head is not removed. The timing chain cover is removed. The head is left in place. Yes, I do own a 2.4L.
98 Z24
RIP Specks
I have 103,000 miles on my 2.4L. The water pump is original and I just replaced my DexCool at 100,000 miles.
I expect it will go bad at some point, don't know when.
None of the manuals I have read say that the head has to come off. Only the timing chain cover.
I have no plans to do it myself. I'll call my dealer and my favorite mechanic and do a cost comparison when the time comes.
Head stays on.....take it from me I've fixed this , the timing cover comes off but not the head thank fully if it did you'd need a new head gasket too whoever informed you the head comes off has their head up their ass.
<br><img src="http://memimage.cardomain.net/member_images/8/web/728000-728999/728095_1.jpg">
Yes officer I knew the speed limit was 50
agreed^ ........Luke said the head has to come off
head stays on exhaust manifold and timing cover come off looks harder than it is with some experince
I've put two in on my 96 Z not really that bad if you know what you are doing, but still a full days work. One at 100,000 and one at 170,000
Gm calls the water pump replacement a 6 hour job according to a friend of mine...
Do the math if you take it to a dealer.
Where did you hear such nonsense?
& I own 2 of them. The HEAD DOES NOT have to come off.
"Your Premier Source For Automotive Neon & Accessories!"
Add my name to the list...
My 2.4 hit 130,000 miles last week and the water pump began weeping. I'll dig into it next month.
I appreciate those who commented from their experience. Thanks.
