A couple more noob questions - Newbies Forum
Monday, June 27, 2005 5:44 PM
Hi, everyone. I was just wondering how do you check the airfilter in a 2000 sunfire? Do I just unplug those 2 plugs attaching some wire, unscrew the 4 screws and lift up that plastic box looking thing to check underneath? Also, how simple would it be to install aftermarket intake (something similar to one of these: http://www.raceperformanceparts.com/catalog/images/is7000.jpg)? I hear you can make your own intake pretty cheap that works just as fine ... r there any tutorials or FAQ on making one? thank you very much
Re: A couple more noob questions
Monday, June 27, 2005 11:35 PM
yes
very easy. just need a screw driver. install takes about one hour.
have not realyl seen one on the ORG. you can always get a cheap intake on Ebay. like $40 and it does the samething as the one you posted
Tuesday, June 28, 2005 5:37 AM
i wouldnt say an hour. 10 mins tops. just buy one off of ebay for like 30 bucks. an intake is an intake. there isnt a difference except price
Tuesday, June 28, 2005 7:20 AM
^^ in experience would take an hour and from what this guy is asking he is inexperienced. dont get me wrong though everyone has to start somewhere.
Madjack wrote:Like I said before, building an engine like ours (2.2 or 2200) is a painstaking chore , since there is so few custom made parts. It's frustrating to me too, but that's what I like about doing this engine, it's the challenge.
Tuesday, June 28, 2005 9:19 AM
probably take me 3 hours and a 6-pack, lol. I checked the air filter and it looks clean. Thanks for the help Does that plastic box direct cooler air from downwards for the intake? It looked like it might be some sort of heat shield for the air or something. Would the air from the kind of intake I listed above in the pic be warmer since I assume it would be comming from closer to the engine? (though I understand the less turns/wider tube of the aftermarket would be superior). When I install an aftermarket intake, do I have to completely remove that plastic box?
I appreciate the tip on the intakes ... probably saved me some $$ thnx guys. So there is not much of a difference between these 3 except the price? (the cheaper one actually looks like it has less bends/better shape??)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7983304300&category=38634
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7982607715&category=38634
http://rksport.com/product/p_020933211/view_detail
One last dumb question, lol. When I was fidling around with the air filter, I noticed behind the plastic box (outside of it), some sort of pebble or something must have fallen in some time ago. I tried to pick it out, but it just fell deeper into the car to what I assume now is underneath the plastic box. Is that gonna cause any problems in the future?
Tuesday, June 28, 2005 9:43 AM
forgot to mention, the pebble was about 1 x 1 centimeter or so
Tuesday, June 28, 2005 10:04 AM
less bends is easier to install i have the same one, but if you go with ebay you might as well get a cold air like
THIS
pretty sure that one will fit since it is the same engine.
about the pebble if it didnt fall INTO anything it should be good.
Thursday, June 30, 2005 6:34 PM
Yea i just changed the intake on my car all you have to do is unbolt that and unplug everything oxygen sensor..... the filter is right inside the plastic casing
