Sorry I didn't search but I kind of need a quick answer. My reverse lights won't work. The one bulb went out and I changed them and they still won't turn on. I checked the connections to them around the trunk area and they seem fine. The one guy mentioned a reverse switch down inside where my shifter is. I have a 2000 2.2 5-spd with the B&M short throw which I installed myself and the reverse lights were working after I put it in. Is it possible it came loose or something? Anyhelp would be nice.
Also, my blinker bulb for left turn signal went out inside the cluster. Anyone know if thats just an easy change like changing any bulb? I know how to get to my cluster and take apart my dash and all. Just need to know if theres anything special for it. Thanks.
Actually the reverse switch is not in the console by the shifter . It is on the transmission close to the left side fender well . If you follow the wiring going down from the engine to the speed sensor on the tranny it will go onto to the reverse light switch .
The blinker is a little harder if it is blown , because it is an LED diode and is soldered to the circuit board . Not sure where you can go to get one like they are using on our cars . I have already taken mine apart and have seen that they are a little different than what they sell at Radio Shack .
<a href="http://users.adelphia.net/~rdbryant1/index.html.html"><img src="http://registry.gmenthusiast.com/images/mrgoodwrench/personal_pic.jpg" border=4></a>
So its inside my drivers side fender well? When I change my CAI filter I'll take a look at it and see if I can find it. Thanks for the help.
