Brake pads are my first guess. Was it more like a screeeeeccchhh!!! and does it do it all the time, or just that once?
Sam
Ban low-performance cars, not high-performance ones.
I agree. It sounds like it could be the start of the wear indicators.
There's a piece of metal on the pads, and when the pads get low this piece of metal starts to hit the rotor. Which makes a sound when braking to let the driver know it's time to change them.
could be the ball joint in the wheel well........
"Silver 2001 Cavalier z24 5 speed 2 door sunroof and power everything "
AEM Short Ram Intake
B&M Short Throw Shifter
p.s. any noise like that can't be a good thing... but not necisarilly a bad thing...
get it checked out..
I totally butchard the spellin gof necisarilly..
the only thing that will do like a whistle is the brake pedal and it's NORMAL.
Gilles
2.3 Ho
its your back lifting mechanism on your reserve lock out dampener the o-ring on it gets worn then the bearing gets un lubricated and fails.
jk
could just be one of 'those sounds' not good not bad.
-Borsty
Borsty wrote:its your back lifting mechanism on your reserve lock out dampener the o-ring on it gets worn then the bearing gets un lubricated and fails.
jk
i was gonna say
are you talking about
2006 Cobalt SS 2.4L 9.6 @74mph 1/8th mile w/2.28 60ft
my brake pedal produces a hissing sound (which can be like whistling ). This is caused by the pedal going down and air gushing into the chamber for the power brake.
There is actually a foam filter covering the hole where the pushrod from the brake pedal moves in and out of the power brake.
