OK well when I use it to turn left it is normal both front and back work right. When i go to turn right it goes hella faster then the left and in the front only the top corner light goes on and off and the bottom has nothing. Also when I turn my parking lights on the right turn signal light comes on and stays on for awhile. I checked all the fuses and took them out and put them back in. This has happend before and it was just the fuse but this time I have no idea. Any help would be apperciated. Thank you!
2nd place is the 1st loser
i think maybe you have a blub burned out. im not sure cause i cant really understand your post
Check your bulb sockets cause it could be melted jus' like what mine did....
bad bulb. the one side blinks fast when one is out
ok. So the bottom blinker is out. How do I get to the bottom turnsignal. I know how to get the one by the head light but never have messed with the one in the bumper.
that sort of thing happened to me once. i took it to the dealer and had it fixed. i guess some of the wiring in the light that was the problem went bad. i tired the bulb first and then the fuse. nothing worked. took it to the dealer and they fixed it.....sad i had to do it cuz of some damn light tho
how much did it cost?
Im not even going to read anymore...
The subject that you typed "Another turn signal problem/thread" implies you know that there are other threads concerning the same problem. Im sure your answer could be found in minutes with a forum and/or library search.
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/personal_pic.gif">
<A HREF="http://www.sandstorm-j.741.com" TARGET="_blank">Pictures and More</A>
<A HREF="http://www.crush007.com/love.cgi?id=1112583099dpm" TARGET="_blank">Love And Sex Life Prediction</A>
Sandstorm-J wrote:Im not even going to read anymore...
man ur tons of help! No I ment another turn signal problem/thread due to this has happend to me before.
You need to take out the headlight and then you can reach the signal in the bumper. Twist the bulb out and put the new one in. Getting the bulb back in is a pain tho
<img src=http://img.photobucket.com/albums/v502/brad_sk88/NewSig.jpg>
^^Thank you much man! I will prolly end up working on it today cuzz it is freakin 65 degrees outside I love it!
It didn't cost too much to fix the whole problem....maybe $50,i don't remember.it was a long time ago and it hasn't happened since
Ok get this. I am driving this morning to church put on the right turn signal the one that is messed up. Well I look down and it is normal. I was like what in the world is going on. So when I get to church get out to look and see if it really is working and it is! I dont know what in the world is goin on. Thank you for the help.
prolly is the dash lights of maybe a fuse....?i don't really know,just trying to use common sense i guess
Ok well either God does not like me right now or my car is just weird. This morning coming to school it was going fast again but yesterday it would be ok then later on it would go fast again. I guess I will just have to get under the hood and get the lights out and see the bulb. Off to my Cisco class.
it sound like there is a short in the wiring some where so unless you know someone who wires cars your prolly gonna be stuck taking it somehwere and paying them to do it
