On to the next Project- Leaving reaper behind - Photos & Media Forum
Tuesday, May 28, 2013 8:48 AM
The Reaper
I bought this car 2 years ago and it needed quite a bit of work. From the motor to the suspension this car has been completely reborn and into what I think it was intended to do in the first place. Everything on this car has been reworked. The motor has been bored, bottom end gutted and lightened for fast rotation and quicker RPM. The suspension was all custom made with KONI race and HyperCO springs. The transmission was outfitted with a True LSD. This car is really a beast. I had a ton of fun working on it and making it what I think was a pretty neat car. The outside of the car was kept pretty original from back in the day. I would like to sell this to a forum member just to keep it living on for years to come.
I will be sad to see it go but looking forward to another project soon to come.
Mark
If you are interested in what we have done here is the list from what I can remember.
Engine-
Stock 96 block- bored .060
All Clevite 77 bearings
Hot tanked block
Crower I beam rods
Cp custom flat top pistons 10.1 compression
Swain tech coated pistons
Deleted balance shafts
Deleted factory oil pump system
7qt Dry sump oil system
Barnes 3 stage pump
Lightweight Factory balancer pulley
Rotating assembly fully balanced
Ported and polished head
1mm Oversized valves
Titanium Retainers
2.3 QUAD 4 HO cam shafts
2.3 QUAD 4 HO cam shaft housings
Cometic MLS head gasket .035 thick
ARP Rod bolts, main bolts and head bolts
Custom made Oil pan with heatsink
Custom made Tubular Header
Custom made LOG manifold with velocity stacks
TTR upper motor mounts
Poly lower Mounts and Transmission mount
80MM throttle Body
Phenolic head Spacer
T3/T4 turbonetics turbo
3" Dump all the way to back
Aluminum exhaust from firewall back
Electric WaterPump
Becool 3" core aluminum radiator
160* Thermostat
Fuel LAB AFPR
Tial Waste gate
Tial BOV
Suspension
Custom made KONI Race Coilovers with 700# in front and 800# in back Hyperco Springs
Custom made Tubular control arms
Modified rear torsion beam
BBS 2 piece wheels with BFG KDW Tires 235/45/17
Front Addco sway bar with poly bushings
Wilwood 4 Piston brakes front
Disc conversion for Rear brakes
N Body Knuckle upgrade in front
Camber plates front
Spherical rear Mounts in rear
Custom made Subframe brace
Custom made K brace
Custom made rear Triangulated rear brace
ABS Fully deleted
Bump Steer Kit Custom made
Custom made Overflow tank
Transmission
35k mile 01 Getrag transmission fully torn apart and checked over
Quaife LSD
Spec stage 4 clutch
Rk sport Aluminum Flywheel
ARP Flywheel bolts
Custom fit LD9 jackshaft.
Fuel
10 gallon fuel cell
2 Walbro 255HP Out of tank fuel pumps
Fully walked AN fittings and hose front to back
42# Green tops injectors
Custom built fuel rail
Aeromotive Adjustable FPR
Other
Custom built roll cage 8pt
AEM Boost controller
AutoMeter boost gauge
Autometer Water temp
Innovate Wideband
AutoMeter Oil Temp
AutoMeter Oil PSI
Sparco seats
Scrotch 3" harnesses
Emergency Battery cut off switch
Front and rear Tow Hooks
http://www.overkillengineeringmotorsports.com/
Re: On to the next Project- Leaving reaper behind
Tuesday, May 28, 2013 8:57 AM
Definitely an awesome car, wish I was in a position to make a fair offer on it!
Tuesday, May 28, 2013 6:56 PM
This is a sad day! This thing is awesome! Hope the next owner puts it through its paces and takes good care of it.
Tuesday, May 28, 2013 7:13 PM
i hope some high school girl gets it and drive it into the ground MARCUS!
how dare you sell this thing! hahaha it does suck but i know the business needs fresh meat. cant keep projects once they are done.
M45/OS crank/2.4 snout. It's nice to be injected but I love being blown!
Wednesday, May 29, 2013 6:34 AM
Exactly guys. I am sure it will go to a good home. Right now it looks like it will be a while before I even come close to selling it. You never know, I might just hold onto it if I cant get the price I want. This was 2 years in the making and I am sure to not just dump it. If anything Ill give it to a family member.
Wednesday, May 29, 2013 7:44 AM
Id love to buy it, but it is way out of my price range
Wednesday, May 29, 2013 7:52 AM
Price?
Wednesday, May 29, 2013 7:58 AM
15k. Parts alone are close to 20k not including orignal price of car.
Wednesday, May 29, 2013 8:09 AM
Not that I doubt your values at all, but you won't sell it for that nor near that and I'm not being rude, but that's just a sad fact.
So in short I'd count on keeping it .
Wednesday, May 29, 2013 8:19 AM
If I able, I would buy it.
Wednesday, May 29, 2013 8:20 AM
Sure many would, but truthfully people with 15k to splurge for a spare fun car aren't typically Cav shopping!
Wednesday, May 29, 2013 8:34 AM
Joe Schulte wrote:Sure many would, but truthfully people with 15k to splurge for a spare fun car aren't typically Cav shopping!
Agreed.
Wednesday, May 29, 2013 8:39 AM
I thought the same thing with my Lumina Z34. There is a buyer for every product, just a matter of finding that person. I am in no rush to sell it.
Mark
Thats not saying that I wouldnt take a little less.
Mark
Wednesday, May 29, 2013 10:30 AM
Why are you selling exactly? Did ya'll ever get the tune dialed in?
GMR has got nothing on this
Wednesday, May 29, 2013 2:10 PM
I want to see this car fully tested, it has yet to be really run through the paces and see what it can really do.
Thursday, May 30, 2013 5:24 AM
DOHC_tuner wrote:Why are you selling exactly? Did ya'll ever get the tune dialed in?
Would like to move on to another platform.
Thursday, May 30, 2013 5:25 AM
Addicted to meth wrote:I want to see this car fully tested, it has yet to be really run through the paces and see what it can really do.
Mee too. Just right now I would like to see it go to a good home and be taken care of. I dont have much time these days to pull engines out and be working on it all the time. With a car like these you have to have plenty of time to tinker with it.
Mark
Thursday, May 30, 2013 12:43 PM
Ugh... another one bites the dust and won't reach it's full potential.
This happens far too often in the J-body community - an awesome car (in this case unbelievably amazing car) gets built and is full of potential that this platform has almost never seen before and the project grinds to a dead halt when it comes time to tune/finalize the vehicle and see what it can do.
I don't mean any offense at all Mark... it's just heartbreaking to see this car come SO CLOSE to being what it can be.... and now there is a high chance it won't. I really wanted to see it tuned to within a hair of its limits and then tracked to all hell showing what the suspension you designed can do as well as the heavily modified engine.
I'm not one to talk - in fact I'm the last one to talk about that kind of thing - but with that said it just makes me sad. I was so looking forward to seeing the results of re-engineering a J-body into something it clearly was never meant to be.
-Chris-
-Sweetness-
-Turbocharged-
Thursday, May 30, 2013 5:39 PM
I have to agree with Joe, unfortunately. The fact of the matter is that the jbody scene is full of cheap asses who don't appreciate the time and money put into a car, and expect everything to go for next to nothing. With any luck, maybe you'll end up keeping it long enough to take it 100%..
R.I.P. JessE Gerard 7.11.87 - 1.25.08
The Radiation Nation Facebook Twitter Twisted Metal Alliance
Thursday, May 30, 2013 8:03 PM
As i started pulling the motor today i got the itch again. Im have some what of second thoughts. For now ill leave it for sale . Im thinking of a few new parts to make. All custom one offs that wont be for sale.
Almost am ready to drop motor and trans to fix the loose flywheel.bolts. updated pics later on
Saturday, June 01, 2013 6:25 PM
Sunday, June 02, 2013 1:21 PM
that thing looks bad azz
Sunday, June 02, 2013 6:40 PM
I'm happy to see that you are fixing it. Question. Why pull the whole powertrain instead of just the transmission?
Monday, June 03, 2013 6:11 AM
It took me 3 hrs by myself to pull it. Now I can see if there are any hidden problems that I could not see with just pulling the trans. Also when you pull the trans by itself I always noticed that the shaft can contact the fingers on the clutch and I really dont want to replace any other parts. Right now it looks like the turbo is shot. Its been rebuilt 3 times and after a run always comes back with serious shaft play.
Mark
