2001 Z24 turbo build *56K WARNING* - Photos & Media Forum
Monday, February 13, 2012 9:02 PM
Well i guess its time to let the cat out of the bag. Here are my pics of the car so far and my list of mods as follows:
2001 z24 5 speed manual
2.4L LD9
Wiseco 9:1 pistons bored .020 over
Eagle Rods
Clevite 77 main and rod bearings
2.3 oil pump swap and balance shaft delete
Z spec Aluminum stock size crank pulley
ARP head and main studs
Cometic .035 head gasket
Car Customs 1mm bigger SS valves
ported exhaust side and polished combustion chamber bowl of head
secret cams (for now)
TTR custom made SS log manifold ceramic coated
Turbonetics 60-1 T4 ball bearing turbo
custom made 3" o2 housing and dump tube for wastegate
Turbonetics racegate wastegate with 9 psi spring
racetronix w body fuel pump intank
siemens deka 80# high impedance injectors
2.3 H.O. intake manifold
RSM 62mm throttle body
fuel pressure gauge mounted on fuel rail
2.2 coil conversion with MSD coil packs
8mm autocraft spark plug wires
NGK tr6 plugs gapped .028
TTR upper engine mount
Prothane transmission mount inserts
RSM lower dogbone aluminum/poly mount
-6an oil feed
-10an oil return to oil pan
CX racing 31"x12"x3" intercooler
2.5" charge piping with t bolt clamps
GM reflash with tuning via HP Tuners
Innovate MTX-L digital wideband kit
Spec Stage 2 clutch
Spec aluminum flywheel
Greddy Profec B 2 boost controller
Tokico Dspec struts
Dropzone lowering springs
Front and rear strut braces
Things to come:
Team green LSD insert
Spec stage 3 clutch
Driveshaft shop stage 2 axles
H.O. Cams with hex insert and CPS pad
MSD Dis 2 ignition
-8an feed and return fuel lines
3" stainless steel turbo back exhaust
BF Goodrich G force t/a drag radials and g force t/a kdw2 rears on 17" srt-4 wheels
Eibach sway bar kit
Tial Q 50mm blow off valve
I still need to figure out a way to hook up that big a/c line and i need to do something with the heater core line because i dont want it sitting on the compressor housing.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Re: 2001 Z24 turbo build *56K WARNING*
Monday, February 13, 2012 9:06 PM
sessy. lets see some videos of it on the road
DOPER.
Monday, February 13, 2012 9:15 PM
Looking forward to numbers in car zsince Aaron never got track times with that setup.
Monday, February 13, 2012 9:30 PM
aaron said it put down 545whp so I can't wait to actually get this on a dyno and see where it's at. I'm attempting to tune this myself so I'm going to start out on the waste gate spring which is 9psi and work my way from there
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Tuesday, February 14, 2012 3:57 AM
Sick setup, this Aaron form TTR's old setup? Looks like it'll be a beast to drive.
Tuesday, February 14, 2012 4:23 AM
Finally, some pics of your setup lol. I wanna hear the damn thing run
Tuesday, February 14, 2012 5:21 AM
Baller Shot Caller
I'm jealous...you have some stuff that I want, but will have to wait for next year. Lookin' great!
2004 Cavalier Sedan
Tuesday, February 14, 2012 5:41 AM
awesome. absolutely cannot wait for results from this beast.
id say reroute the ridiculous stock brake booster hose, though. just lop it off at the straight down by the block and go up to the booster from there. no reason it has to go clear the ef up around by the dipstick and all that. i never understood why gm did this...
anyways, looks good man. love all the coating.
Come join us over on the Olds Quad 4 and Twin Cam Facebook group!
Tuesday, February 14, 2012 6:27 AM
im intrigued
Tuesday, February 14, 2012 10:18 AM
It's looking good, that intercooler was fitted perfect !
peformance parts for sale!! Click:
http://www.j-body.org/classifieds/engine/62265/
Tuesday, February 14, 2012 10:30 AM
yeah i planned on doing something with that brake booster hose, it doesnt please me where its at. My goal is to retain all manufacturers options on the car, hence why im still using cruise control. The intercooler even clears the fog lights, i just had to cut the bottom of the bumper a little bit to clear the piping. Im still debating on how to do the exhaust tho, straight thru muffler or chambered?
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Wednesday, February 15, 2012 2:32 PM
something about boosted cavs makes me harder than a priest in a playground.
Wednesday, February 15, 2012 2:51 PM
good to see your retaining your A/C
Wednesday, February 15, 2012 3:24 PM
oh hell yeah i gotta retain a/c. I like to be able to talk @!#$ and be comfy at the same time haha. anyone know what the thread size is on the stock oil pressure switch on the ld9? I need to rig up my oil feed and im nowhere near my car at the moment.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Wednesday, February 15, 2012 3:52 PM
^^ 1/4"
More pics!!
Thursday, February 16, 2012 9:13 PM
lol how many pics u want? Ill take some more the next time im down my garage. What do u want me to take a pic of?
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Friday, February 17, 2012 5:51 AM
Well hell it says "build" lol, figured you were posting progress prics, guess not. HA
Friday, February 17, 2012 8:20 AM
I'm not too much of a fan of how the dump tube merges with the downpipe... and the O2 sensor is too close to the turbo outlet. Needs to be 16-18" downstream from the outlet.
That's enough of the complaints, though!
For the coolant outlet I would find a shaped pipe in an "L" or a simple rubber L and some brass fittings and a bit more hose and extend the length of that coolant hose and have it come out of the firewall in an "L"...
I have AC with a turbo - it's glorious. Keep it. I've looked at all the pics and can't see the clearance to see if I can come up with an idea for your issue, though...
As David said the stock oil threading is 1/4" npt which you will step down to 1/8" for your feed and (hopefully) aftermarket oil pressure gauge. I've retained the stock gauge on my setup but honestly all these years later don't see the point. Leaving it unplugged has no ill effect on the cluster.
When did you sell the M62 kit?
-Chris-
-Sweetness-
-Turbocharged-
Friday, February 17, 2012 3:11 PM
I still have the m62 kit sitting in a box. Id love to sell it, know anyone who wants it?!?! haha
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Monday, February 20, 2012 9:16 PM
UPDATE: Got the oil lines done for the turbo and also replaced few other lines with the left over an line i had. I completely ditched the factory sending unit and just attached a 1/4" npt to -6an fitting to the head and then -6an line directly to the turbo. I also did -10an return line direct to the pan with a 1/2"npt to -10an adapter.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Tuesday, February 21, 2012 4:09 AM
Nice progress, though I think -6an is rather large for a feed line for the turbo??
Jason
99 Z24
LG0/LD9 for Life
10 Year Bash Veteren
Tuesday, February 21, 2012 4:20 AM
Yea that -6 might be a little big for feed.
Lovin the progress.
Tuesday, February 21, 2012 11:09 AM
U think its gonna give me problems? Other members use 6an for feed line so thats what i went with.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Tuesday, February 21, 2012 11:20 AM
Tuesday, February 21, 2012 11:47 AM
Yea man id go with -4. Unless like Mark stated, go with a big enough restrictor. I even have a restrictor with my -4 feed. You will blow seals if too much oil, will smoke too.
