thanks guys im actually gonna take some more.. down here in GA.. soo more to come!
GOT ECOTEC?
what are those wires for?
Dave (2 UNIQ) wrote:thanks guys im actually gonna take some more.. down here in GA.. soo more to come!
they are actually zip ties that i tied to the back seat straps to let down the 60/40 rear seat.
GOT ECOTEC?
Looking great! Love the ninja ziptie seat straps.
More like chair force
Kidddding.
I'm diggin' the car though.
________________________________________.
Still not low enough for a signature.
Never liked those tail lamps, but they really work well with your car
Very nice
Buddy Club Ecotec Cavalier
* More to come *
Well how about that you this car is still around, and you haven't become a homeless guy in queens.
Hi Dave
Want hub spacers or rear disk brackets? Shoot me a PM.
friend of mine had his hood recleared to fix the issue.
- T.
did they sand it down then re clear it?
GOT ECOTEC?
yes sand it down then reclear
GMR has got nothing on this
thanks im not sure what grit to use and i know ill def need a sanding block. recommendations?
GOT ECOTEC?
If you take a piece of carpet like what you used for the sub cover. You can cut a square and put it where the latch for the seat goes and you will always be able to just pull them down.
true.. never crossed my mind to do that.. thanks great idea
GOT ECOTEC?
Dave (2 UNIQ) wrote:thanks im not sure what grit to use and i know ill def need a sanding block. recommendations?
use 1500 grit followed by 2000 grit. use wet sand paper. then its your choice but the next step is to either buff it or have it clear coated. if you use a good buffing compound and a spin style buffer you should be able to get it to look like new.
MRThompson (jrthompson) wrote:Dave (2 UNIQ) wrote:thanks im not sure what grit to use and i know ill def need a sanding block. recommendations?
deffinatley appreciate the help..!
GOT ECOTEC?
well i sanded it down with like 800 cause the 1000 grit wasnt doing jack, then i got some of the carbon fiber to show.. but i might just get a shop to do it. and re clear it.
ill take pics to show the progress. i still have to hit it with the 2000 grit.and see what happens
GOT ECOTEC?
