My Boost Thread - Photos & Media Forum
My Boost Thread
Monday, July 19, 2010 9:30 AM
Ok since i have seen no actual ecotec boost build guides with pictures i think i will start one as described in adams(NJHK) sticky threads u will learn alot from there as well i will just post pictures with info on what i am doing as for my build here is the info
16g turbo, hahn turbo mani, non intercooled charge pipes for now( do have an intercooler but just waiting on piping) turboXS BOV, also have a hahn BOV, Hahn downpipe, braided oil feed line with tap block adapter, rubber oil drain, oil drain adapter, 16g gasket + flange, GLow shift gauges + a piller, (boost/vac, wideband afr, oil pressure) with 3 gauge wiring adapter, necessary vac lines and clamps, all running on stock 2.2 eco for now only 8psi for fuel just using lsj green tops(injectors) fmu possibility. For Tune i will be using HPT hopefully ben can make it up here so i dont have to do the local shop tune 250 bucks plus 85 bucks an hour.....@!#$ty
For first setup just cleanin up downpipe, mani, chargepipes, and turbo b4 and after pics.
b4 clean up
and after clean up
Here is stuff for build
oil feed
oil feed and oil pressure adapters
intercooler
TurboXS BOV
turbo xs
Hahn BOV(not using)
Glow shift
again
3 gauge wiring harness
A-Pillar
oil drain adapter(Iknow this is for turbo side but it will work till i get it welded and there is no leaking so far)
gasket+flange ( didnt use flange due to space)
@!#$ty Boost controller...for now
AEM 30-4100 Wideband Gauge EUGO 6 in 1 Controller(Not my photo still on way in mail)
Ecotecforum on FaceBook
Re: My Boost Thread
Monday, July 19, 2010 9:31 AM
here is 2 spots you can tap the head for oil i will be tapping both 1 for oil feed and the other for oil pressure
now the size is M12 x 1.75 you can find a fitting on jegs, summit racing websites. I actually ordered the 1 from jegs it was like 18 bucks for the fitting it comes here and it doesnt fit my oil feed but does fit my oil pressure sender so worked out
here are some pics of the head on driver side just under ICM wires
here is the 2 taps
here is one 3/4 threaded out
here is 1 completely threaded out of the hole there is a lil oil drippage but as long as the car is off it shouldnt shoot or pour out
more to come....
Re: My Boost Thread
Monday, July 19, 2010 9:32 AM
preview of turbo setup
Re: My Boost Thread
now i have pics of oil feed line tapped and installed
and capped off for now till i do the build this weekend better to get some done now
Updated 7/6
heres is what i ended up doing i flip the oil feed to the center of the head and the oil pressure to the right side so it can fit. As you may notice the black oil cover under neath the oil feed has to be shaved down a bit not a whole lot just a bit for oil feed to fit. also depends on what size fitting you use. so here you have it
Re: My Boost Thread
Monday, July 19, 2010 9:34 AM
Ok just got done pulling the oil pan off drilling and tapping well here are pics enjoi
Re: My Boost Thread
Monday, July 19, 2010 9:35 AM
build pics i will get more soon on my other camera here are a few enjoi...
my old 4-2-1 header dont care i still miss it goin on my buddies J since he helped with build(i wish i can get paid n ....header)
these headers are not fun to take off or put on due to the straight up bend, Where the bolts go of course.
turbo mani installed with 2-1 header pipe still in.(welded) waited to cut off
turbo installed on turbo mani. didnt think it would fit due to the preview pics....but fits perfect.
as for the downpipe pics will be up soon. When installing same with header both hit the cross member cover underneath i would suggest trimming up a bit with a whiz wheel or something. This can depend on your setup if it rubs cut this but not too much
here ya go
really almost did the ECU relocation but it was the 4th of july needed to party a bit
G-Money helpin out
random
also not to offend anyone
This is what you get for working on your Eco all day in the sun with no shirt on the 4th of July .....still hurts
Top of charge pipe with BOV and Vac line
here is a pic of the custom intake i made but also important the Vac lines T-off for boost gauge...color coded
Black Vac line to T is from Intake Mani fold
Yellow Vac Line Is From Wastegate actuator
Clear Vac Line Is from Boost Gauge
and another close up of the lines with illistration
here is the intake manifold nipple locations just to the right and down on the Throttle body i think they are coverd in blue caps if there not dirty
here are the carge pipe routes under the car as you can see NON Intercooled but Will be soon.
From compressor housing down uand under tranny and back up to TB
here is a picture where the downpipe comes off the turbo and clears the firewall
and another
Re: My Boost Thread
here are some local j's in goshen .....offtopic random pics enjoi
My Baby Girls J 98 Z24......which was just sold....sad day
Rosey's J(g-money)...SLAMMED!!
Re: My Boost Thread
Monday, July 19, 2010 9:36 AM
I installed my gauges just got my wideband afr today so i went to town and let me tell you not a fun time.
A-Pillar
Wideband AFR
Boost
Oil Pressure
WIDEBAND WOOT
also have a video i did of the gauges
non tuned stock boosted eco(i do not beat it.)
Re: My Boost Thread
Monday, July 19, 2010 9:37 AM
Ghetto tb setup till i get my IC piping
and lsj injectors....they work
Re: My Boost Thread
i know i know, trying to get done b4 the bash well anyway here some pics of stuff i got today
IC Piping
Turbo Ecotec badge
My badass shirt i made
Re: My Boost Thread
Monday, July 19, 2010 9:38 AM
Got Intercooler and piping on and all mounted Finally!
Bumper off
side view
stupid airbox and winshield wiper fluid tank....delete
intercooler sittin on jack
side view of charge pipes
under view
Everything mounted
ready to ride
Re: My Boost Thread
Monday, July 19, 2010 9:42 AM
Woot for progress all i need is tune FTW
Re: My Boost Thread
Monday, July 19, 2010 11:03 AM
Nice job man, I just dont like your TB setup lol, waaay too many places for leaks.
Re: My Boost Thread
Monday, July 19, 2010 11:06 AM
I hate it as well but sure enough doesnt leak did the cig test haha
pipe routing kinda wierd but works real good
Re: My Boost Thread
Monday, July 19, 2010 11:08 AM
great freakin work dude!
should be fun when you start driving it!
Re: My Boost Thread
Monday, July 19, 2010 11:11 AM
plus the fact tahmy cahrge pipes are 3 diff colors i only used 3 pieces out of the piping kit i just got (polished) and 2 i got from a buddy (black) and the 2 non intercooled chargepipes i made intercooled lol (BLue) but the @!#$ works and doesnt leak im sure maybe somewhere lmao but to my knowledge with my cig i got know movement with the smoke.
Re: My Boost Thread
Monday, July 19, 2010 11:12 AM
been driving it since the 4th of july she runs fine as long as i dont beat on her all i need now is a tune from Ben davenport
Re: My Boost Thread
Monday, July 19, 2010 2:11 PM
I wouldn't have tapped the pan where you did, should have done the dimple in the girdle. Where you have it, the oil in the pan is going to back flow into the oil return line. Keep an eye on everything to make sure your turbo is actually draining oil and not burning it.
Re: My Boost Thread
Monday, July 19, 2010 7:47 PM
well guess what guys worked like a charm sits perfect and slid over like a glove
dirty as hell from sittin in the garage
ENJOI
Re: My Boost Thread
Monday, July 19, 2010 10:33 PM
^^^^^ bug collector FTW lol
2010 Lonestar Bash 2nd place J-Body Street Class
Re: My Boost Thread
Tuesday, July 20, 2010 3:09 AM
Cody @ RD Fabs wrote:I wouldn't have tapped the pan where you did, should have done the dimple in the girdle. Where you have it, the oil in the pan is going to back flow into the oil return line. Keep an eye on everything to make sure your turbo is actually draining oil and not burning it.
x50. Tapping the oil pan on a Ecotec is sense less. They have the perfect spot to be tapped from the factory.
Re: My Boost Thread
Tuesday, July 20, 2010 6:00 AM
Yes i know completely sensless i was going to tap the one of the plugs on the girdle but the motor was in the car i will prolly do it soon this was jsut to get it running i will be picking up a new oil pan form the yard and tap the girdle pretty soon
Re: My Boost Thread
Thursday, July 22, 2010 5:36 AM
and Now HP Tuned!
Re: My Boost Thread
Thursday, July 22, 2010 8:33 AM
Congrats Jarrod, now post some videos! haha.....
peformance parts for sale!! Click:
http://www.j-body.org/classifieds/engine/62265/
Re: My Boost Thread
Thursday, July 22, 2010 9:14 AM
love it love it love it!
arrival blue and 95-99 z wheels ftmfw!!!!!
