forgot to add, thanks a million to ((Super))KbRedCavy for being a reliable guy. got it sent to me as quick as possible. i would suggest buying from him if he has a part for sale that you need.
I wouldnt worry too much about it, unless there is a hole going into where the fluid would be then you can either have it welded or just jbweld over it. I have delt with a ton of trannies that a chunk of the bellhousing cracked off, as long as its nothing around the fuild, dont worry, thats just a bolt up point to the engine, and missing one really isnt going to kill you or the car. Wont even notice it, other then when u look at it. Other then that, enjoy!
Man that's an all to familiar sight. The one we took out of my car cracked right there, just make sure there's no mounting point right there mine had a mounting tab there. As for swapping the case. It's ALOT harder than it sounds, I got mine split open and just got overwhelmed by the amount of work.
Member of J-body of Michigan.
For Sale
alright so today im going to clean it and then once the weather pics back up (stupid bipolar colorado weather) ill be putting it in with lots of photos
happy you got like i said! good luck with the install, it was a PITA to install mine!
Mods: Synapse Charge Piping, Short Throw, Bad-Mab Dp, Dejon Intake, BYT Tuned!
Parts For SALE! Pacesetter Header(ECO),17'in Resonator, Alternator, Starter, Viper Alarm.
i know it will be a PITA but its better than spending 500 dollars at aamco for them to put it in. plus it'll be a learning experence if someone else needs it done i could make some good cash off them
Drop the subframe or do the PJ mod and cut off that tab on the subframe.
Install is not that bad, took me and my buddy a couple hours to swap mine, but that included plenty of rye and smoke breaks.
Looks good tho!
newt wrote:Drop the subframe or do the PJ mod and cut off that tab on the subframe.
Looks good tho!
pj mod? detail on what that is? i planned on cutting it anyways, just sounds easier
The driver side subframe extends farther than it needs to, and then is back cut on an angle.
If you cut it so the cut is now vertical it will drop out much easier.
You will figure out what piece it is as soon as you try to pull the tranny out the bottom...lol
Its kinda hard to explain, but if you search you might be able to find the post on here.
It is honestly easier to take the subframe out. Alot more room to do it.
zsquee24 wrote:It is honestly easier to take the subframe out. Alot more room to do it.
yep that's what I did. Tried the pj mod was easier to just drop it.
a how to on dropping the subframe?
z yaaaa wrote:other than the nasty hood dent, steelies, 4X4 ride heidt, crooked front license plate, body color b pillar covers, 2200, lack of tint, and overall boringness of the car id say she's perfect!
SLO CAV (the autoxing one) wrote:zsquee24 wrote:It is honestly easier to take the subframe out. Alot more room to do it.
Really?! I found it ALOT easier to cut the tab off. Don't have to mess with the bolts, brake lines, power steering crap, etc. I don't see what is so hard about getting it out once the tab is cut off.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
x3 On dropping the subframe. Takes 2 mins to get the trans back up with the subframe gone.
does anyone have a how to on dropping the subframe?
its a lot of bolts, the the big black thing under the front of the car...
do i need to drop the whole thing or just the one side?'
prolly best to take the whole thing out
WHAT SIZE BOLTS GO THROUGH THE TRANNY MOUNT! 14 IS TOO SMALL AND 15 IS TOO BIG!!!
got the mounts off, got all the electrical stuff off, got the bracing bars off, got the bell housing bolts out, got that piece of the subframe out of the way, got the axels out, now is it just a matter of wedging it out?
YUP, you gotta get if out of the clutch flywheel and crank, be careful
just slowly slide it out and down?
now i just realized the AC like was attached to one of the bolts and i just thought it was a stud, how do i get that AC line off of there?
OMG man... go buy yourself a haynes manual!!!!!
ps, love the quote hahahaha
All I want... is a little of the good life
