^^picture fail
2003 Cavalier Black Base, 5sp. Enkei Evo 5's in Hyper Black
Okay, lets try this again:
![](http://i154.photobucket.com/albums/s271/blakcvy03/100_1613.jpg?t=1270510202)
Quick wash:
![](http://i154.photobucket.com/albums/s271/blakcvy03/100_1627.jpg?t=1270510261)
They're on recommended settings, which is fine for me. I'm working on painting various brake pieces black so no more rusty awesomeness, wheels are 17x7 w/ 42 offset no rubbing at all, clears the suspension.
are these coil overs or just the tein springs? i want something that will have my car dumped and right now its lower than most of the cavys i've seen. i just heated my stock springs and dropped my car 3.25 in front and 3.5 in rear. it sits a little higher than i want it but im having trouble finding some coil overs that will go around 4 inches or lower!
20cavy02 wrote:are these coil overs or just the tein springs? i want something that will have my car dumped and right now its lower than most of the cavys i've seen. i just heated my stock springs and dropped my car 3.25 in front and 3.5 in rear. it sits a little higher than i want it but im having trouble finding some coil overs that will go around 4 inches or lower!
These are the full SS coil overs. To go as low as you are wanting, would blow these. I don't know how low the STD's go, but they have a setup where you can lower w/out killing your coilovers, which the Teins don't have. Check
this thread for more info on that. I bought these for simplicity of installation.
2 coilover set I know so far that will make J's real low with little shock travel sacrifice:
-STD's.....John Benham, supposably
-Granavas ( B&G RS2)....ebaymotors.com and www.urbanworx.com
why?
-Double Ride Height Adjustability
instagram: peru_stylez
I dont wanna threadjack but mine is lowered on STD's
they can go lower but you'll need to cut frame and "adjust" your wheel wells, which I need to do.
again sorry...
op - Rear needs to come down at least another inch
LE61T PTE6262 Powered
