looks really good. only suggestion is to re wrap the door panels. the red just doesnt clash, and something with the seats as well. other than that. its badass
You do some good painting my man. Looks great
sweet paintin skillz man. I love how it turned out. Good job
Hamburger Helper..One Pound, One Pan, One Disfunctional Family!
and how do you take the mirror apart?
@!#$ looks good man!
props for painting inside the cupholders if it didn't bubble up!
SEXY!
-Markus
2002 Yellow Cavalier LS Sport
looks pretty sweet man!
glad to see those skirts put to good use!
sweet looking stuff
love that color
Lookin good man. Question i have is did you use a 2k primer or that dupli-color can i see in the pic? If you did use the rattle can did you let it flash for 24 hours before topcoating it with the base? We've tested that stuff and ther is no adhesion to the rattle can stuff with in the 24 hour mark because of it still flashing off and it also reacts because of the two different resin bases.
jnickel wrote:and how do you take the mirror apart?
I believe all you do is remove the spring. PITA I've heard.
not bad good job keep it up
![](/global/images/emoticons/jbo.gif)
thanks for the comments everyone and keep them coming.
X OpTiMo X wrote:Lookin good man. Question i have is did you use a 2k primer or that dupli-color can i see in the pic? If you did use the rattle can did you let it flash for 24 hours before topcoating it with the base? We've tested that stuff and ther is no adhesion to the rattle can stuff with in the 24 hour mark because of it still flashing off and it also reacts because of the two different resin bases.
yes i'm guilty of using the rattle can. it was around 12hrs before the paint on the door panels, everything else was over 24hrs even the fender. which is the only piece i had a problem with. on that i think it was more of a problem when i sanded it for primer.
jnickel- eternal is right just remove the spring. sounds easy but is really hard.
Very nice! I love that color.
i demand better (bigger) pics today, outside in the sun!
and what did all of this run you, if you dont mind me asking?
also, what guns did you use? you mentioned you didnt like them in another post
here's a link to
flickr for larger photos. unfortantly i didn't have anytime to mess with the car today due to trying to catching up on sleep and having to work 12pm-8pm.
also price was i thinking around $200-$220. actual base and clear only ran $160.
Edited 1 time(s). Last edited Tuesday, April 22, 2008 8:12 AM
looks good....great paint skillz
GMR has got nothing on this
looks great man...
the only complaint I have is that the red on the interior does clash with the blue like someone else said...
other than that, awesome.
its cool bro just wondering. But you shold be ok since it was out of the 24 hr range. When we tested this at PPG, inside that range there is still a solvent lingering in the primer and when it is based then cleared it would trap the solvent in and it would react with the resin base of the base and clear causing it to bubble and eventually peel off. Looks good though, I concur with tabs get some outside sun pics
gotta love that price
![](/global/images/emoticons/ad.gif)
btw....youve got a PM about the guns
