oh and also for anyone that wants to upgrade nuts and bolts nuts for bottom are 10mm by 1.5 i used nylon lock nuts on those and the main motor mount bolts are 12 mm by 1.75........u can get nice zinc plated bolts at lowes very cheap.............
Lookin good, just makes the engine bay look cleaner!
Looks good greg, can't wait to get my 2.2 mount soon. TTR FTW!!
The01Cav wrote:Lookin good, just makes the engine bay look cleaner!
thanks alot man i want the other mounts aswell......
I'd suggest you make sure those bolts you bought are grade 8.8 or 10.9, you don't want them snapping on you... the upper motor mount takes a lot of force.
" To study and not think is a waste. To think and not study is dangerous. "
Dave Dunsmoor wrote:I'd suggest you make sure those bolts you bought are grade 8.8 or 10.9, you don't want them snapping on you... the upper motor mount takes a lot of force.
yup 8.8 most metric bolts that size are 8.8 thanks for the input ..........
just found this when i googled i might just order the best 12.9 in the 12mm x 1.75 check out the chart i found as a reference.......
Metric Bolts
Maximum Torque, in foot-pounds, for clean, dry threads
Check your Shop Manual ! Bolt size Low Grade, Grade 8.8, Grade 10.9, Grade 12.9
6mm 3-5 7 10 12
8mm 8-12 17 24 29
10mm 15-22 33 47 57
12mm 39 59 83 100
14mm 60 101 131 158
16mm 60-94 146 202 247
18mm 60-130 201 283 340
20mm 166-188 285 401 482
nice, very clean engine bay. i love it. u decide on what to do with the ac line? zip tie, or make a bracket... get one off a ford fusion or a eco J?
Just lookin out for ya dude, there are a lot of bolts made to sub par standards... trust I'd know, spent a whole month sourcing hardware for mounts I designed for a $25,000 digital projectors... you don't one of those to fall haha
Like I said though, 8.8 or 10.9 will be good enough, so I wouldn't worry about it if yours are stamped.
z yaaaa wrote:nice, very clean engine bay. i love it. u decide on what to do with the ac line? zip tie, or make a bracket... get one off a ford fusion or a eco J?
gonna make something at work...i am a machinist .......that did not even think on the bolt grade lol so i am going to order the max 12.9 grade........
The J-Z wrote:looks good
thank u sir......u know i like ur cavy........
