Being the unemployed guy I am, I got bored yesterday and decided to take a few pictures of teh car and do a lil work.
Took pix of all sides including the dent my ex-g/f's mom and my mom put....on the same spot!!!!
Heres a close up of the dent...dam ex-g/f's mom n mine!!!
Heres pix of the lil work I did. I decided to spray paint my intake pipe with a metallic blue paint. Also took off my HVAC knobs and sprayed them blue.
Heres the pipe all finished and installed. Compared to the old look, it looks much better all blue than polished and black lol.
BEFORE
AFTER
no more cavy...now 240 =]
I see a cool-air intake
It's got a NOS-fogger system and a T-4 turbo
I see an A.I.C. controller
It has direct port nitrous injection
Yeah, a stand-alone fuel management system
...Not a bad way to spend $10,000
That crank case vent is supposed to have vacuum.
wow dude your car got rocked! intake looks good
Member of J-body of Michigan.
Cherubim wrote:That crank case vent is supposed to have vacuum.
So where the lil breather filter is, theres supposed to be the hose from the intake?
00Cavy wrote:Cherubim wrote:That crank case vent is supposed to have vacuum.
Yes, where the breather filter is, there should be a hose that runs to your intake tube. This provides a little bit of vacuum. The filter dosn't, and it looks kinda silly sticking up like that, in my opinion.
Cherubim wrote:00Cavy wrote:Cherubim wrote:That crank case vent is supposed to have vacuum.
oooo k, so then wats the point of having breather filters? I thought it brought a lil bit of air into that section. Im a lil bit of a newb at these things but IM learning.
Breather filters are minimally functional decoration. Some intakes arn't designed with the correct tube attachments, which means you can't run that stock tube to the intake. So, you've got to put something over that hole you created, and a breather filter works. Tt might make someone a couple extra dollars on top of that.
