is there a box behind that trunk setup? cant really tell. looks like its a bit small if there is one there. but bezel and setup looks pretty good.
good work. keep it up!
The bezel looks really good!!
2004 Turbo cavalier 11PSI and blown!
a little dusting and you'll be looking real good.
why does the fiberlass box look completly destroyed? it looks all cracked and messed up, what gives?
bezel is awesome man, good job.
z yaaaa wrote:why does the fiberlass box look completly destroyed? it looks all cracked and messed up, what gives?
looks like he put plastic wrap on it for the pic
i love the gauges! you should have given your subs more airspace, but it all looks good
Niiiiice
correct me if im wrong but if the paint isnt cured and the dust is on there, when it cures, there is gonna be dust stuck into the bezel
The paint isnt wet it was just soft the clear was cured and it was just soft not sticky.. i was afrad to dust it off cuse of scratching it....... THE trunk unit was wraped in plastic so it didnt get scratched....would you guy lett me know which way the subs look better inward or outward....same with the compresser which way it looks better behind the tank or on the side... thanks for the comments
keep the valves towards the seats and do one sub normal and one inverted
[quote=ßãggéÐÇåv98 (Ûñqùðtäߣè Øñé)]correct me if im wrong but if the paint isnt cured and the dust is on there, when it cures, there is gonna be dust stuck into the bezel
wetsanding and buffing is your friend.
I like the bezel a lot. It seems like a lot of people are working on the same kinda stuff. The sub box looks sweet too. I would follow the above advice on sub placement and tank direction.
Man that is beautiful! I wish i could do something like that!
