well here is links to the pics since i left them full size , and ive got 29 pics , lol
special thank to TTR and aaron , going to all the work to have these made for us !!!!
installed on a 00 2.4 s/c auto trans , i do have the idle speed up'd to 725 rpm when hot , instead of the 550 it was at , thanks to HP tuners , currently the upper is the only mount i had , ill be installing my lower back in the car in the next couple days
vibration was a little different at start up , and noticeble as the idle speed droped down , but wasnt worse than the insert , it was just different , and not in a bad way
aaron go ahead and copy and save the pics so you can use them , i took to many to email you , lol
tools used to swap mounts , i used my impact gun to make things quicker , a 10 mm socket and15mm socket were used , and i used simi deep sockets , extensions for presonal preference in length , screw driver and 2ft pry bar -
http://www.azjbo.org/forum/album_pic.php?pic_id=264
1 10mm bolt removal for the coolant bottle , in 2nd pic becarefull not to knock the clip or it will fall into the inner fender area -
http://www.azjbo.org/forum/album_pic.php?pic_id=289 ,
http://www.azjbo.org/forum/album_pic.php?pic_id=257
2 screw driver used to pop the bottle outta the inner fender -
http://www.azjbo.org/forum/album_pic.php?pic_id=287
3 15mm nut removal for a/c line to mount -
http://www.azjbo.org/forum/album_pic.php?pic_id=286
4 screw driver or something similar to undo clip -
http://www.azjbo.org/forum/album_pic.php?pic_id=285
5 a/c hose clip save for later use -
http://www.azjbo.org/forum/album_pic.php?pic_id=284
6 move coolant bottle aside for axcess to 1 15mm nut for mount on inner fender -
http://www.azjbo.org/forum/album_pic.php?pic_id=283
7 2 more 15mm nuts on inner fender to remove to get mount out -
http://www.azjbo.org/forum/album_pic.php?pic_id=282 ,
http://www.azjbo.org/forum/album_pic.php?pic_id=281
8 upper plate removed -
http://www.azjbo.org/forum/album_pic.php?pic_id=280
9 upper plate in hand to so it doesnt do much -
http://www.azjbo.org/forum/album_pic.php?pic_id=279
10 remove 2 15mm bolts on engine side -
http://www.azjbo.org/forum/album_pic.php?pic_id=278 ,
http://www.azjbo.org/forum/album_pic.php?pic_id=277
11stock mount with insert upper plate off -
http://www.azjbo.org/forum/album_pic.php?pic_id=276
12 stock mount with upper plate on -
http://www.azjbo.org/forum/album_pic.php?pic_id=275
13 stock mount and TTR mount -
http://www.azjbo.org/forum/album_pic.php?pic_id=274
14 stock mount upper plate removed and TTR mount -
http://www.azjbo.org/forum/album_pic.php?pic_id=273
15 with coolant bottle up slide mount into place , and lower bottle back down , in some cases the motor will move as shown by pics , use pry bar to move motor to line up with mount -
http://www.azjbo.org/forum/album_pic.php?pic_id=272 ,
http://www.azjbo.org/forum/album_pic.php?pic_id=271, http://www.azjbo.org/forum/album_pic.php?pic_id=290
16 then screw the 2 15mm bolts in BY HAND FIRST , then tighten up the 2 15mm nuts -
http://www.azjbo.org/forum/album_pic.php?pic_id=270 ,
http://www.azjbo.org/forum/album_pic.php?pic_id=269
17 make sure a/c line is clear of bolt on the mount -
http://www.azjbo.org/forum/album_pic.php?pic_id=268 ,
http://www.azjbo.org/forum/album_pic.php?pic_id=267
18 a bolt is needed to attach ac clip to mount -
http://www.azjbo.org/forum/album_pic.php?pic_id=266 ,
http://www.azjbo.org/forum/album_pic.php?pic_id=265
i didnt use the clip , to keep my a/c line from rubbing the s/c bracket , it was rubbing with the stock mount , and there is enough room with the new mount to move line down , but clip wont be used , i will need to find a clamp that will hold it down lower , just to prevent the hose from vibrating to much
19 final pics , for the ooooo aaaahhhhhh factor -
http://www.azjbo.org/forum/album_pic.php?pic_id=261 ,
http://www.azjbo.org/forum/album_pic.php?pic_id=260
20 over all engine shot , gotta clean the c/f cover so i can add ttr sticker -
http://www.azjbo.org/forum/album_pic.php?pic_id=263
Edited 1 time(s). Last edited Wednesday, October 18, 2006 9:08 PM
