This is what I picked up on the 24th of last month. Got it for $6,500 with 42,000 miles on the clock...managaed to talk them down from $7,880 so I did't do to bad. It had came with a custom dual exhaust, cross-drilled and slotted rotors, and 16" alloy wheels with Kumo tires. Since then I've swapped over the VIS Evo hood from my '96, removed the side moldings, added an auto transmission interceptor, and an AEM cold air intake. Today I also ordered a header and upper and lower motor mounts. Well, on to the pictures...
In the fairly near future I will be installing a set of Wayson F-1 fenders that were going to go on the '96, but since I never painted them they never went on. The only other thing I have planned to get done before the end of Summer is to swap the suspension over but that is going to cost me $300 - $400 after its all said and done. As you would expect all questions and comments are welcomed.
now this is only my oppinion but i think that fires should do smooth, and that hood just breaks up every bit of smooth this car has, along with the fenders you have planned
i dont know not my taste but good luck with it
IMO yes the sunfire has smooth lines, i think you should get some coils, eibach wheel spacers ( u have to get VW ones ) and get some projectors and ull be set for exterior then get a little go in there...but hey its not my car so do what you want
CHECK OUT MY DOMAIN!!
http://www.cardomain.com/ride/2236703
Ya i also have to agree with the hood breaking up the stock lines of the Fire
x2
NEW SIG COMING SOON FOR 07'!!!
