how do you get that rear speaker deck out from a sunfire?
Opening Soon Kustom J's
my question is how is the starter going to be incororated?
j/k looks like a good start.
your speaker magnets must be tiny for a 6x9 cause mine hit the metal in the exact spot u put urs did you make sure it fit before glassing?
sndsgood wrote:have u put it back in the car and checked it, if you let the glass dry like that theres a chance that when it cured it bowed the front piece out and it may not fit right.
Yea, fitment could be an issue. I learned that pretty quick. Suggestion is to let it cure some, then install it so it can fully cure and not warp.
Wide Body Progress
whats with the starter???
Later
David
I need photoshop...cause its time for a new sig
It fits Ive checked it. Right now I got foam shaped around the speaker bezels for the contouring, It almost ready to lay down the crushed velvet and start fiberglassing and filling.
15.149 @ 91.26mph 3-18-2006
BlackEco wrote:It fits Ive checked it. Right now I got foam shaped around the speaker bezels for the contouring, It almost ready to lay down the crushed velvet and start fiberglassing and filling.
Crushed Velvet to fiberglass over??
My Car Domain
You are going to hang something relatively heavy that vibrates by rings of plastic , only attatched by a small surface area of fiberglass on the top of the rings?
You are much more brave than I..... I would put money on a speaker grill breaking free from the glass and falling to the deck..... especially when you have magnets just mm's away from metal like that.
Looks good otherwise.
Cardomain|
Myspace
I have a notched wooden block epoxied between the deck and the plastic bezel, the fiberglass could still crack around the ring, but they are pretty well locked in. Only one way to find out.
