Well,
I ran on the dyno today. Was trying to get some base numbers before I do any modifications. I have a 2005 Cavalier and the dyno was performed at Cars-N-Effects.
Here is the dyno image:
And here is the video:
Base Dyno
Numbers where:
Max Power = 127.91
Max Torque = 135.22
Hope you enjoy.
Defined Parts
Cool dealeo man, wish I could make a run.......
Niiiiice, I wanna dooo thaattt
2012 numbers - 4SPD
AUTOMATIC!!
wow, we are really close in our baselines!!!
my first dyno was with a 62mm TB and it was 130.1
and that was 3 years ago...
good job, what are your plans?
LE61T PTE6262 Powered
damn work for not letting me tag along DAMN IT!!!!!!
very nice festa cant wait to see it put out some real numbers
Thanks guys,
QBE my plans for my first modification to the engine is boost. I am planning on doing the GM charger if it comes out before the end of 2005. Otherwise I might have to break down and go turbo like yourself. Other than boost though I do not intend on any other engine modifications to be performed until the end of 2006, I plan to work on exterior only.
Defined Parts
Nice run. Good numbers. And good work on the video, the car sounded sweet hittin the dyno.
Awsome video festa....ill upload those pictures tanight.
that's the strangest dyno graph i've ever seen. looks more like a wave graph than a dyno graph.
CNFX>vbz wrote:The smoothing wasnt on.
care to explain more? is this something that just happened to be on with every other dyno graph i've ever seen or what?
it's some nice numbers, but the graph is just... strange.
03Bomex, go to Epic at the beach they have a dyno there and ou can run it.
DvBoard wrote:CNFX>vbz wrote:The smoothing wasnt on.
Hello DvBoard,
Yes usually smoothing is on by default, there are different levels of smoothing which make it the way you see in most dyno graphs. I asked for it with out any smoothing. I would rather see the raw data, but that is just me. Also when you enable smoothing it actually lowers the numbers because it averages out between spikes and finds the most common values, therefore giving you a more naturally accepted image yet less accurate in my mind. Granted the numbers only changed a couple HP you are talking probably about maybe +/- 5 hp with smoothing. Either way my stock expectation was to see between 120-130 hp based on 1/4 times and vehicle weight so this is just about right.
Defined Parts
ok i was just wondering. just seems strange to see so many spikes. i've never hada car worth putting on a dyno though i i don't know all those options
