I took the tint off of my windows and some of the glue remains on the inside of the window. Any ideas on how to get this crap off my windows?
If it's on the door and quarter panel windows it's best to use a nice sharp blade and soapy water in a squirt bottle.
If it's on the back window which takes more time to get off, use soapy water and a scrotch pad. Like the ones for dish pans.
Don't use the blade on the back window cause you might cut your defrost lines and they won't work after.
But that's what I use and had no problems at all. Plus it was warm outside and that helps soften the glue. Plus if it's on the back window i'd take the back carpet piece out, makes it easier to get down at the bottom of the window and won't soak your carpet.
Good luck
Proud member since 99
thanx man! I'll try that out tomorrow prob
i used a razor blade and invisible glass
a ton of goo-gone, I was playing around with the brother-in-laws rx7(took iff ugly purple tint), and a little on a rag took it off like nothing else, then clean with any window cleaner of your choice.
cheers and good luck
my roommate said something about goo-gone the other day. do they sell that at auto zone or advanced auto? I'll check into it. thanx guys
walmart. hear its near the checkout and about $1 for a small bottle
alcohol works fine with razor blade.
Goo gone works wonders.
Let it soak in for a couple minutes then it takes it off like it's nothing at all.
goo done did work wonders. I did like you said Tay-Ok and it came off with a little razor work. Thanks guys..
nail polish remover
Working on obtainting an M-Class license... ?? Hint: 2 wheels.
