Is it just my cav or does anyone elses blow heat from the vents when everyhting is turned off? What have you done to solve this so nothing blows through when the blower is turned off? I have duct taped the vents for the time being, but that looks pretty sh!tty. Any ideas ?
98z24, lowered 2", aem intake, cat-back striaght pipes!, cop ligths in the front and rear, 18" liquid metal's, primer black, tint, full audio and video.
I dont know why, even if you turn them off it'll keep blowing it does in all gm vehicles ive had. The easiest thing to do is if its hot out keep it on the cold end or if its cold out turn it to hot etc.
Is it just barely blowing, or is it always wide open.
barely blowing.
yeah since thats the case all ive done is either change it from cold to hot etc or change where its blowing like changing it to the defrost etc. I'm pretty sure its meant to be like that cause even my mom 2005 Pontiac G6 GT does that
Ok... I guess its just an annoyance I have to deal with!
matthew christian wrote:Ok... I guess its just an annoyance I have to deal with!
You can always put it on Recycle / Max without turning the vent on, this will close the vents to the outside.
