steering wheel problem (need help) - Interior Forum
Monday, October 13, 2008 12:49 PM
How can i take the steering wheel of my 98' cavalier with out blowing out the air bag. I looked around the steering column and i didn't see any screws. So i didn't @!#$ with it. (Can any body know how)
Re: steering wheel problem (need help)
Monday, October 13, 2008 1:11 PM
yea theres plenty of write ups. first you disconnect the negitive terminal on the battery and pull the air bag fuse. a steering wheel puller is required to remove the wheel.
Monday, October 13, 2008 1:34 PM
where can i find a steering wheel puller at cant i just rip the air bag out and there should be a bolt holding it out isn't there. Cause i have another steering wheel to put on it
Tuesday, October 14, 2008 7:48 AM
most parts stores sell or rent a puller
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
Tuesday, October 14, 2008 7:49 AM
are you putting a cavalier wheel back on? or going aftermarket?
Tuesday, October 14, 2008 11:58 AM
im going aftermarket
you have a steering wheel hub right?
Tuesday, October 14, 2008 1:48 PM
After removing the negative battery terminal, there are two bolts on the back of the steering wheel(10mm I believe).
I can post a pic if you'd like.
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
Thursday, October 23, 2008 5:16 PM
i forgot i had a steering wheel puller and bought another....now i have 2....doh. the only problem i had was removing that dang tilt wheel lever.
Thursday, October 23, 2008 9:16 PM
The tilt wheel lever is just a simple screw in piece. At least thats how it is on the 97 cavalier I have.
Friday, October 24, 2008 3:03 PM
i had to use a vise-grip and just rip it off...sanded it down alittle to get the grooves from the vise off and put it back on.
Saturday, October 25, 2008 6:55 PM
There's 4 tabs in the back of the stock wheel that hold the air bag on man. After that's off the rest is simple. One big ass bolt to remove LOL.
5K PB: 24:50
10K PB: 54:26
Sunday, October 26, 2008 3:50 PM
I am having the hardest time on the final step the steering wheel puller. I stripped the smaller bolts and now I will be using a tap to make the holes larger to get the damn wheel off. It's on there pretty good and i'm tired of beating on it and yanking. I did see someone say they did not need a puller, I would like to see an example where it would have to be "hit" to not need a puller. Any help is appreciated.
FOR SALE
