Hello,
the digital display for my odometer is flickering. If I fiddle around with the trip meter knob it will straighten out for a bit and then return to flickering characters (looks like mostly 1s). Almost seems like a loose connection. Anyone have this before?
Thanks,
lbrowne
i just had this same issue, replaced the cluster, everything was good to go.
Are you able to program the mileage correctly? How can you do that.... legally
Can't see a way to edit previous posts, but I read that on 00+ you can just swap to another cluster because the cluster doesn't store the mileage? If so that should be easy to fix, nothing else I have to swap over?
For the 00+ models mileage is stored in the bcm instead of the cluster, so yes you can swap to any 00+ Jbody cluster.
So anything after '00 and before the pursuit. Thanks!
mines doing the same thing so im going to replace is it simply plug and play or is it like the pre 2000's where you have to bypass the anitheft
thanks
plug and play
![](http://i17.photobucket.com/albums/b72/bLk99cAv/slvrblitsig1.jpg)
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
It's plug and play however, the cluster stores the trip odometer as I just found out. The odometer count is stored in the BCM.
