What color is the wire and or what is the pin location for the marker light? I want to hook up my fog light switch to this so I can run my fogs wiht my markers. I just currently have it tapped into my cig lighter so they can be turned on at any point. If anyone can help me out with this that would be great. Thanks.
![](http://img.userbarz.com/49/9606.jpg)
would that make them flash tho? or is there another wire that is used for the flashing signal?
_______________________________________________________________________
my carDomain updated 3/6/07 Boosted at B-day!
I would think that there is another wire for flashing. I just want the running lights so that I can pick up the signal for the switch that way when I turn off the markers it also turns off the power to the foglight switch. Or if anyone has any other suggestions i'm open for that as well.
very very easy larry but your gonna wanna run an HID style relay and direct power to the battery so the parking lights are only used as a trigger, or your lights are gonna be dim.
A simple way to do it is to use a multi meter in the socket and find what give you power when the parking lights are on and what give power for the turns.
JGM T-SHIRTS!!!!
![](http://img525.imageshack.us/img525/7068/satchmoesigonepiecejgmoz8.jpg)
Could I also get the signal from the dimmer switch in the car? Reason I ask is because the Z24 I pulled the switch out of had the wire spliced together too the dimmer.
