Manta Z(The Primered One) wrote:- Have the wheel straight before u do any of this..
- Disconnect - terminal
- Pull airbag fuse, let car sit for 10min and then press brakes(some say this step isnt needed.. i didnt do this or the second step listed here but i list just for ur safety..)
- 2 10mm(maybe 7mm.. cant remember.. doing this by memory..) bolts on the back of the wheel hold the airbag in, the bolts will not fall out so just unbolt them till teh airbag comes free.
- Disconnect the airbag connector, horn, and negative lead
- Remove Steering wheel nut(unsure of size.. sorry)
- Use steering wheel puller and remove the wheel(be sure when tighten the bolts down for the puller to tighten them evenly.. dont tighten one all teh way down then do the next one, chance of breaking the bolt in the wheel
- Remove C-clip on the shaft, then pull out the Airbag clock spring(white/yellow plastic circle behind the wheel)
- Disconnect the airbag clock spring by following the wire to a connector
- Take your MOMO hub and line the top hole striaght up and make sure the arrow is also pointing up. (the square hole in the MOMO hub should be right infront/ontop of the hole for the horn wire to go into)
- Tighten the Steering wheel nut
- Install horn wire(varies each wheel but get me pic of the wheel and horn wires and i can easily help you out)
- Set and align wheel on hub and tighten all ur screws
- Insert fuse and reconnect the - terminal
- Test horn
- Start car and constantly turn wheel back in forth and make sure the wheel is on securely.. increase how hard u turn as u keep turning..
Thats basically the how-to of what i did.. after reading through it multiple times i cant think of any step i've might have missed..
Manta Z(The Primered One) wrote:u will need a air bag simulator for ur pass airbag to work propery.. with ur airbag light on it will not allow either airbags to function.. removing the fuse wil also disable the seat belt light.. it will constantly flash or stay on.. most just use a simulator or like i will do is place electrical tape over it on the inside and it will just be hidden.. still on but not visible..
chad spender wrote:where does one find a airbag simulator like mentioned in this thread?
