does anyone know how or if it is a bitch to take off the under dash and bascially dash to paint. i took out the trim bezel and top but i need to paint the rest. if anyone has any advice its must appreciated!!
The "Under Dash" is the entire dash. From bottom to windshield strip. In order to paint the under part, outside the car, you have to remove the entire molded plastic dash. It is a bear to remove. And very time consuming. If you can paint it inside the car, it would be suggested.
DsMotorsports (NEO-Js) wrote:The "Under Dash" is the entire dash. From bottom to windshield strip. In order to paint the under part, outside the car, you have to remove the entire molded plastic dash. It is a bear to remove. And very time consuming. If you can paint it inside the car, it would be suggested.
that should never be a suggestion unless you like half assing things
as much time as you need to tape off the entire care to properly paint inside the car you could have taken the entire dash out. it takes an hour to do at most, and really isnt hard at all, just takes time to get all the bolts out and remove everything, removing it is definatly the best option in my opinon because it save you the risk of accidently getting paint on the interior or exterior of your car.
is it possible to remove those round vents in the 04 sunfire dash in order to paint them w/o takeing the entire dash off? sorry to thread jack you also.
