shorter shifter - Interior Forum
shorter shifter
Thursday, May 01, 2008 5:53 PM
is there a way to shorten an auto shifter?
Re: shorter shifter
Thursday, May 01, 2008 5:55 PM
you didnt search... did you...
Re: shorter shifter
Thursday, May 01, 2008 6:00 PM
i looked but i figured its easier to ask
Re: shorter shifter
Thursday, May 01, 2008 6:04 PM
marc lannon wrote:i looked but i figured its easier to ask
that works both ways... easier for me to tell you to look for it yourself than to find the thread and post it for you.
Re: shorter shifter
Thursday, May 01, 2008 6:05 PM
ack.......cool, just some late night reading.....but its not a hard mod is it?
Re: shorter shifter
Thursday, May 01, 2008 6:42 PM
Not hard at all. Use a hacksaw to cut the shifter down, just be careful not to cut through the yellow "stick" in the middle.
Re: shorter shifter
Thursday, May 01, 2008 6:50 PM
Click Me
this is the first one i found... just ignore the stuff about cutting the bottom and welding it.... the stuff your looking for is a little further down
Re: shorter shifter
Friday, May 02, 2008 1:07 AM
Look about three quarters down the page. Cut the outer pipe with a pipe cutter being careful not to cut the yellow rod. Thread the outer pipe to match the T-Handle. Drill the T-Handle for the yellow rod. Install T-Handle. Trim rod to your liking. Done.
http://www.j-body.org/forums/read.php?f=45&i=93837&t=93837
If you want to reinstall the stock T-Handle, cut the outer pipe to length leaving the yellow rod. Use a grinding wheel to cut two slots in either side of the outer pipe for the stock clip. Trim the rod to activate with the stock button. Install T-Handle and clip. Done.
