I need to know how to remove the fish eyes in the door panel's have have tried using paint thinner, washing the panels with soap n water and i still can't get rid of them.... i am getting really frustrated with it.... i need some help please. thanks
Ok u need to color sand and buff start with 1500 then 2000 if there still there use 1000 u need bucket warm water some dish soap in the water.
step 1 let the 1500 paper soak then rub on the ish eye with even pressure,
step 2 2000 the same spot, that will take out 1500 scratches. now it will look hazy and have some fine scrahezzzzz. in it ok but dont worry buff time.
You will need a medium cut compound, called solo its good sht.... i used it everyday at the body-shop. if you know how to buff you will know how to use it.
just turn it on and go over the area of fish eye's you will need to have a polish to remove the film form the solo, get some shat called excite, also good stuff,
if you need more info ill be glad to help, But thats the way to do it, it was caused bu silicone in the painting process
Airbrushman.
