ok guys im trying to reinstall airbags into my 2002 cavalier. i need to know the part # on a 2002 caalier module. i found the wires under the carpet... also i need to know if anyone has a writeup or pictures on how to reinstall the clockspring... i tried to reinstall the clockspring today but its not working very well.. im not sure if im missing something or what...
From what I found, as long as you didn't snap the weak tabs of the yellow piece, you should be ok. Just make sure it's properly oriented, but it's mainly hit-or-miss to get the alignment bang on if you didn't marker the direction like you should have before you started.
Once you get the "feel" it goes in like a glove.
Best advice I have for you is to go to a wrecker's and buy one from a blown-airbag wheel. That yellow disk will cost you an arm and a leg through GM.
2002 Sunfire -->
- Ractive steering wheel
- ASA 17" EM9 + Nexen N5000 215/45/17 (steelies for winter)
- D-Spec Lowering kit @ 1.4" (issues currently
- Rockford P250.1 + MTX MZS1004 + Panasonic CQ-C8313U head unit
- Barely legal tint.
well when i put the clockspring on the wiring coming out the back hits the plate thats behind it?? anyone have a write up??
