So i dont have power windows, sadly, but I am thinking about changing that.
I have the console without the window switches in it, and i wanted to swap it for one that does, to start out. Has anyone taken out/ put in a console before? And is it a fairly difficult job?
Later on I would prolly get power doors from a junkyard, and do the wiring, then get the car painted again.
Thanks
you can just swap the cover peice that holds the switches into your stock console as long as there from the same style console. if you wanna swap the whole thing its pretty straight forward. 4 10mm bolts hold the console in place and abour 5 or 6 13mm nuts hold the mounting brakets in place.
good deal.
i also want the power window console right now cause theres a blowout on C/F accents, and theres one the goes over the switches
But could someone tell me where the bolts are located , for the console? lol
Just look at the console... there's 4, 2 where you lift up and there's a cubby, and 2 at the front I believe... check team forward motion, I'm sure they have pics... btw... if you can't figure out how to take the center console out, I'd advise against putting in power windows, not to sound like an ass or anything.... Just don't want to see you bite off more than you can chew.
There will always be someone faster than you, but thousands slower and dumber than you.
dude, its not that i couldnt figure it out. i havent even checked out where the bolts are or anything.
i am thinking about doing it, and was getting some input from others
isnt that what 85% of ppl on here are doing?? getting input from others.
thanks quicklilcav, great info from ya
