Need wiring harness, will make it very worth someone's while. - Interior Forum
Monday, January 21, 2008 12:33 PM
Pains me to have to reveal this, but dealership cannot help me because my own VIN is soo far off the beaten path from the year and trans i need this for. Also there are no local Pick N pulls with cars that new in it.
DASH WIRING HARNESS fully intact with no missing connectors for 03-05 manual transmission( or 00-05 if someone can verify they are all the same). From the BCM to steering column multi-switches , key tumbler, ignition switch, OBD2 port, Clutch Safety Start switch, brake light switch, air bag SDM, AIrbag, HVAC, and all that good stuff. The .org member i am getting all the conversion parts for this swap isn't sure if he has this harness or not so i just want to be safe and if i end up with 2, then so be it.
I will make it worth someone's while if you have an extra or can get me one. So who out there has or can get me one
Edited 1 time(s). Last edited Monday, January 21, 2008 12:33 PM
Re: Need wiring harness, will make it very worth someone's while.
Monday, January 21, 2008 2:56 PM
I have a 2000 here 5 speed here
Monday, January 21, 2008 3:13 PM
Can you take a picture of the harness for me please?
Monday, January 21, 2008 5:37 PM
oh, and without ABS.
Tuesday, January 22, 2008 7:51 AM
I have the dash apart, what portion of the harness did you want? I'll see if I can take it out this week sometime, it's pretty stormy and cold here
Tuesday, January 22, 2008 9:02 AM
Everything except the harnesses that run along the length of the interior doors of the vehicle. By the false pedal there is a connector for that. I need the BCM, and everything in the dash, where it connects with the engine wiring harness, Headlight harness, up over the steering column, to the multi-switches, hvac, and also the air bar wire that runs to the air bag control module.
or w/e harness that the clutch start saftey switch and harness that runs to the steering column key cylinder.
Edited 1 time(s). Last edited Tuesday, January 22, 2008 9:50 AM
Tuesday, January 22, 2008 2:10 PM
OK can you give me a small how-to for taking this harness out? I'll get it out and snap some pics for you ASAP. How much are you willing to pay for it? I have no idea how much it's worth.
Tuesday, January 22, 2008 7:51 PM
There really isn't a how to. it require tearing out the whole dash and the front passenger side carpet. In order to do this there is several screws and ground wires, connectors that all need to be unplugged. Steering wheel needs to be removed and the whole nine yards. I was tipped off to car-part.com by another member and actually have found a dash wiring harness for an 03 manual trans cav in Tennessee for $110 dollars. I wasn't able to get a hold of them because i found it around 6pm and they closed at 5. Then another one in Portland Oregon for $300 shipped for a 2005. I will update this tomorrow and let you know whether or not i will still need yours or not.
Tuesday, January 22, 2008 8:29 PM
ok
Wednesday, January 23, 2008 5:38 AM
$125 shipped from Tennessee out of that 2004 manual Sunfire.
Thanks tho.
Saturday, January 26, 2008 8:25 PM
I have one (already out of the car) from a 03 cavy 5 speed. Had 3500 miles on it. Nothiong wrong with the wiring. This is just the Dash wiring. If you are ionterested contact me.
