99-96 - Interior Forum
99-96
Thursday, January 17, 2008 11:29 PM
hi i need help i have a 96 sunfire 2dr i wont to change the whole inside the car using the front and backs with the carpet from the 99 cavalier because there in better shape than mine thanks for the info
Re: 99-96
Friday, January 18, 2008 4:25 AM
I don't see a question here.
What do you need to know?
Re: 99-96
Friday, January 18, 2008 7:03 AM
will the front and back seat work out of the 99 cavalier in the 96 sunfire along with the 99 carpet can i also use the 99cavalier door on mine to
Re: 99-96
Friday, January 18, 2008 7:07 AM
The seats are no problem, at least I'm 100% sure on the front, 99.99% sure on the back. The carpet is no problem.
However, if you change the doors, you're going to have to change the entire dash, which will include changing the plug on the cluster wiring harness so you can use the Cavalier cluster, which will not fit properly in the Sunfire dash.
My recommendation, unless you want the Cavalier interior, is to get a set of door panels from a salvage yard.
Re: 99-96
Friday, January 18, 2008 7:12 AM
can i use the door panels off the sunfire on the cavalier doors b/c the panels on mine r good but the doors are rusting on the out side but the cavalier doors r not
Re: 99-96
Friday, January 18, 2008 7:34 AM
james barnes wrote:can i use the door panels off the sunfire on the cavalier doors b/c the panels on mine r good but the doors are rusting on the out side but the cavalier doors r not
i dont see why not. the screws should all be in the same place and so should the push in quick rivets.
1997 RedR - ZedR
