Gauges. - Interior Forum
Gauges.
Tuesday, January 15, 2008 5:18 PM
I am thinking about getting some gauges for the cav, probably volts, oil pressure, maybe fuel pressure? What gauges would you recommend? No big motor mods I would just like to keep an eye on things.
Anyway what kind of gauges do you recommend, there is so many different brand. I am looking for something that looks good and is reliable and inexpensive, like I said no big mods so i don't need the best there is. What would you suggest I get gauges to monitor?
Thanks!
Re: Gauges.
Tuesday, January 15, 2008 6:20 PM
im going with autometer, Phantom II's kinda pricey but im also gonna boost. Id still suggest some form of autometer for you.
Re: Gauges.
Tuesday, January 15, 2008 6:46 PM
Ok, I am very new to add on gauges. So this is going to be a very dumb question, what all is involved with installing a volt meter, oil pressure, fuel pressure gauge? Do the guages come with everything you need?
I was looking at the Autometer Ultra-lite series, they look good and are reasonably priced.
Any better things to gauge other than volts, fuel and oil pressure?
Thanks!!
Re: Gauges.
Thursday, January 17, 2008 4:36 AM
I wouldn't go fuel pressure. I'd go with Volts, Oil Psi, and Oil temp or trans temp.
Re: Gauges.
Thursday, January 17, 2008 7:00 AM
why trans temp or oil temp over fuel pressure?
I would have loved to have a fuel pressure gauge when my fuel filter got so plugged the car died completely, which in turn killed my fuel pump, and fuel pressure regulator. Would have saved me a lot of money.
No one has experience to tell me whats involved with putting gauges in?
Re: Gauges.
Thursday, January 17, 2008 8:43 AM
volt meter is simple. 3 wires (power, light and ground)
as far as the other 2 im not positive but if you search in here you'll figure it out. im sure both require a sender
Re: Gauges.
Thursday, January 17, 2008 8:45 AM
they come with what you need to install them. and some basic instructions most of them arent very detailed. but 9 times out of 10 you need more wire to run the gauges.
Re: Gauges.
Thursday, January 17, 2008 10:01 AM
Autometer would be the way to go on guages. Also get the guages you feel you will use the most. Oil pressure for sure, the volt guage is nice as times to see if your system is running right but probably will be the guage you use the very least. (unless you have a system) If you beat the hell out of your tranny then the trans temp is nice as well
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
Re: Gauges.
Thursday, January 17, 2008 10:50 AM
I drive it hard but I wouldn't say I beat the hell out of it.
Thanks!
Re: Gauges.
Thursday, January 17, 2008 2:48 PM
id go with some swoosh gauges you can find um on ebay there nice not cheapo fake ones
Re: Gauges.
Friday, January 18, 2008 4:49 AM
Those guages look awesome, they would match my cluster perfect! Anyone have these gauges, are they pretty good?
Neverheard of them before.
Thanks!
Re: Gauges.
Friday, January 18, 2008 12:57 PM
i have um but havent had time hookin um up yet paintin n redoin interior
Re: Gauges.
Friday, January 18, 2008 1:10 PM
