Dont Flame my Theftlight Issue - Interior Forum
Sunday, November 11, 2007 10:51 AM
(96 2.2L)(i also used the search)
so i was driving along the other day and hit a huge bump in the road... thats when my theft light came on. it didnt cause any trouble YET. its not blinking just stays illuminated when the car is on. i checked all the cables under the dash and everything is securely connected. does anyone know what the deal could be?
Re: Dont Flame my Theftlight Issue
Sunday, November 11, 2007 11:54 AM
underpants gnomes.
Sunday, November 11, 2007 6:30 PM
Probably some random freak occurance that will fix itself... as long as there are no problems, then no worries.
I would, however, give yourself 10 minutes extra or so whenever you go somewhere in case the theft protection does decide to kick on.
Tuesday, November 13, 2007 8:23 PM
Check the ground wire from the battery to the battery tray. On the 96 sedan I just bought, that ground connecting grommet was slightly rusted, and was causing a similar problem with all the cluster lights. It may have pulled loose in the bump.
Later,
Jack
Wednesday, November 14, 2007 8:26 AM
If a huge bump in the road made it come on...... maybee if you drive over a huge dip in the road it will go off again
I know.... I'm being completely useless.... but I couldn't resist.
Something almost had to come loose..... find out what parts of the car are wired through the teft system and go from there.....
I don't know much about it.... but I'm pretty sure the ignition switch is one of them.
Thursday, November 15, 2007 2:23 PM
Check the wires going to your ignition cylinder. These wires are a small gauge wire and often have issues. Just make sure they are attached and intact. If that doesn't fix it go to the dealer.
Thursday, November 15, 2007 4:18 PM
if your certain its not an issue, unplug the battery for thirty minutes. my dads colorado did something like that, so he just unplugged it and reset it. worked well enough
